Oooooops Salas conected heater ground to elevated tubes
False alarm, ground heater connect right to lower valves
Salas both SUT connections are OK?
Just put 20K on Valve Itch's input when using the 977 as SUT and nothing on the SUT itself. The other explanations and ways perplex you, so skip them.
I wonder If it would be possible to duplicate/mirror the circuit to make it balanced
Of course but you will never have the level of matching required for good CMRR with so loose tolerances that tubes will produce in open loop circuits like that.
To the contrary when using a balanced impedance primary SUT like the Jensen you automatically enjoy very good CMRR.
- Analogue Source
- Valve Itch phono
