Valve Itch phono
diyAudio Chief Moderator
Joined 2002
Yes I know my fault sorry, I guess tubes are OK or gain measurements results not OK, what do you think?
Not exact mu between sections in same bottle is a very common thing. Due to construction process tolerances and/or age. You just swap tubes between positions or change and swap again for best gain and inter-channel match results.
Joined 2002
You will not calculate or scope anything. Because I have already measured and posted that using a Zobel as the manufacturer recommends has a true and strong effect.
No need you discover America once again.
After you install with final cabling trim, you start with the Jensen recommendation for Zobel and Itch input load. You just listen to 200pF, 150pF, 100pF in the RC and you decide.
Joined 2002
So only one resistor 18-20K across seconday?
Obviously, but if you will install directly across the SUT just make the Itch's input load resistor 1Meg. Else you just install 18-20K as Itch's input load and you leave the SUT alone. When in same box without interconnects I see no real reason you damp right at the SUT's secondary.
Joined 2009
As the attached pic with SUT load resistor 18-20K across sescondaries?
