Valve Itch phono
Valve Itch phono
Old 8th April 2012, 11:39 AM   #611
woodturner-fran is offline woodturner-fran  Ireland
No, not yet! I'm finding it hard to justify opening it up!
/tom waits closing time playing now....
Fran
Old 8th April 2012, 11:39 AM   #612
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
Those MKP caps are in good 1% RIAA tolerance to make a build care free and economical. It was not easy to find 1% in those voltages and it was a must of getting many and having an LCR meter for other brands and types in sane prices. They aren't something special to must substitute an already installed trimmed array of other caps was the deal, or am I wrong in that assumption?
Old 8th April 2012, 12:08 PM   #613
100% correct salas.
But I also wondered how they sound compared to the Russians.... Just me being lazy! Need to just get off my a** and go do it!
Fran
Old 8th April 2012, 01:14 PM   #614
merlin el mago is offline merlin el mago
merlin el mago's Avatar
You aren't wrong
Old 14th April 2012, 12:20 AM   #615
RevMen is offline RevMen  United States
RevMen's Avatar
With the receipt of the SSHV2 board a few weeks ago, I began assembly of my power supply. Tonight I connected all of the pieces and tested it. So far it's perfect. Rock solid voltages at all 3 outputs. The SSHV2 is fantastic. The voltage across the TP points hasn't changed even 0.1 mV since I set it. The B+ voltage hasn't drifted at all, either. Both of the heater voltages are exactly where I set them. This is great.
I got some help on the design of my PCBs from a local EE who I met through AudioKarma. He gave me a lot of good tips, particularly about using lots of copper. I have a few changes I want to make if I ever make another set, but they seem to be working very well so far. I had a few of each made through Silver Circuits, and the build quality is above satisfactory for the price I paid.
I had a custom power transformer made by Edcor. It saves space and looks nice. I've got my chassis cut out and ready to wire. That will be my project this weekend. If everything goes according to plan, I will have music on Sunday.
Old 14th April 2012, 01:13 AM   #616
Salas's Avatar
Valve Itch phono
So far so good. Congrats. Keep us posted about the build and naturally...keep Austin weird.
Old 14th April 2012, 10:59 AM   #617
Best of luck - looking forward to another itch being born....
Old 21st April 2012, 10:02 PM   #618
RevMen's Avatar
Well..... I've got the circuit assembled, though I haven't physically put the whole unit together. But it's functional so I can test it.
It doesn't sound that good. The high end is very muted. I've attached a couple of samples. One is from my valve itch, the other is using a Musical Fidelity V-LPS. The turntable is a Dual 1229 (that needs a new idler) with a Shure V-15 III cart with a JICO SAS stylus.
What might be the reason for this? What are some things I can try to fix the lack of clarity?
There's also some hum that I'll have to chase down. I think I've got something grounded wrong.
Old 21st April 2012, 11:27 PM   #619
Are you sure you have the RIAA correct?
Old 21st April 2012, 11:32 PM   #620
RevMen's Avatar
Well I checked each R and C against the schematic as I installed them. Most of the resistors I measured on the DVM to be sure. I guess it's possible I missed one. All of the parts I ordered came right off the BOM, so presumably they're all correct.
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
