Valve Itch phono - Page 6 - diyAudio
Old 3rd December 2010, 10:08 PM   #51
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by RCruz View Post
.... must try that configuration.
It will not be immune to the circuit, converts to SE. Can help not picking on the TT cabling run until phono I guess.
Old 4th December 2010, 11:33 AM   #52
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Lundahl specifies that the primary must have a gnd reference... I always wondered why ?
Old 4th December 2010, 11:44 AM   #53
SY's Avatar
Originally Posted by Salas View Post
But, wait a minute... if primary is floating and cart was surely not grounded, that is balanced transfer.
Only if all impedances to ground are equal. That means a carefully balanced primary winding on the transformer, which is not always the case.
What happens if you put a finger on one of the cartridge pins?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 4th December 2010, 01:20 PM   #54
Salas's Avatar
Will see next time I visit the installation. Or will ask. If its balanced good should make no noise? Can I put two equal resistors in the primary and ground the middle point?
Old 4th December 2010, 01:33 PM   #55
Yes.. but it also affects reflect load to the cart.... IMO (as an unexperienced guy in this aspects) it might be quite difficult to match some carts to some TX.
cinemag & dl103 are in love
Old 4th December 2010, 03:03 PM   #56
nhinstruments
RCruz's Avatar
This is a very valuable info.... Thank you
Old 4th December 2010, 03:28 PM   #57
kevinkr's Avatar
DL-103 and Partridge 977 are also in love if 1:6 ratio is sufficient, seems to sound best run straight into 47K, and the best thing is a raw pair will run you less than $80 USD on eBay.uk..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 4th December 2010, 03:43 PM   #58
SY's Avatar
You can, but that "fix" has a limited range and is quite incomplete. If the transformer primary is not well balanced, it's not well balanced, and there's not much you can do externally to fix it.
Old 4th December 2010, 03:54 PM   #59
Salas's Avatar
What is supposed to do when I will touch a cart pin if its well balanced? Will have to wait to know because its still loaned to another HiMC cart system playing without the SUT.
Old 4th December 2010, 03:57 PM   #60
kevinkr's Avatar
If not common mode it will buzz..
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
Copyright 1999-2017 diyAudio
