| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#551 |
diyAudio Chief Moderator
It can be different in tube phono but it looks that's the good range, 18-22k.
#552 |
I have a couple of Shinkohs 18K, 22K are Vishay VSH1
#553 |
GB 1% RIAA caps Elfa answer:
Good morning Felipe First item (65-456-44) now in stock, seconfd item (65-457-01) still not arrived here. Hopefully this week. Please advice how to proceed? Best regards Mats Export Sales Department ELFA AB SE-175 80 Järfälla SWEDEN E-mail: export@elfa.se Phone: +46 8 580 942 30 Fax: +46 8 580 941 11 Internet: www.elfa.se Felipe |
#554 |
Felipe: looks like after christmas maybe?
*************************************** I intend doing the resistor on mine later tonight - butI need to have a good detailed listen before I do the swap. Just in case I'm confused here, or for others coming along after, you do mean changing R1 (47k) for something in the range of 18-22K? Might be worth updating the sch or maybe the parts list to show the change.... Fran |
#555 |
Changing R1 is the test, yes. Can't be recommended for any SUT anyway.
#556 |
So I replaced the 47k with 22k and have been listening for the last half an hour or so. Little enough change, perhaps a little more clean sounding, but not huge......
Fran |
#557 |
Did it change the HF level at all?
#558 |
I don't think so
#559 |
It did bring up HF for 47K VS 18-22K on scope and FFT, but it could be damping better on Itch's input and makes small difference. Still a little more cleaner is enough to keep it there. Is the new resistor quality the same as when it was 47K terminated?
#560 |
Both resistors are more or less no-name metal films from farnell or mouser. Nothing special.
I've been listening more and I do think its a little cleaner alright - just more confident now of my first impressions. The other factor here is the cart - I'm using a benz L2.... Fran |
| Got the build itch again. 80w kt88 | itsmejto | Tubes / Valves | 44 | 26th September 2008 11:49 PM |
| valve phono stage wanted for mc | brobarrie | Swap Meet | 1 | 13th August 2007 08:17 PM |
| Basic DIY Valve Phono Stage | matthew2456 | Tubes / Valves | 5 | 29th March 2007 04:11 AM |
| Phono pre, valve or jfet | lndm | Analogue Source | 7 | 4th April 2006 02:11 PM |
| phono preamp design for c3m postie valve | fergs1 | Tubes / Valves | 1 | 29th May 2005 02:12 PM |
