Valve Itch phono
Joined 2009
Thanks, I supposed not pin compatilbe because I see Russian areselling th adapter.
diyAudio Chief Moderator
Joined 2002
There will be gain, Riaa, and grid leakage differences, bias issues also. Input stage is designed around 6N2PEV special characteristics. Avoid near substitutions like 12AX7. They may work but they will unsettle the specs. Also not pin compatible of course, thus the adapters.
