Valve Itch phono
Valve Itch phono
Old 25th October 2011, 01:54 PM   #491
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Valve Itch phono
Look here: http://www.diyaudio.com/forums/analo...nsformers.html
RC
Old 25th October 2011, 02:44 PM   #492
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Thanks Ricardo, still not clear wich one is the input or output?
Felipe
Old 25th October 2011, 03:32 PM   #493
Default Partridge 977
kevinkr give me the answer: the red pin is the output and the gold/yellow is the input
Old 25th October 2011, 04:04 PM   #494
DL103R (0.29mV output) + Partridge 977 1:6 + Valve Itch 48 dBs will be enough gain?
Old 25th October 2011, 04:51 PM   #495
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
Yes.
Old 25th October 2011, 05:07 PM   #496
Ufff, thanks Salas now I am calm.
Old 25th October 2011, 05:47 PM   #497
woodturner-fran is offline woodturner-fran  Ireland
For anyone else - the linked pins are the grounds. If you measure the resistances, the input side has a resistance of about 25-30R and the output side is higher, can't remember, but significantly higher.
BTW, I broke the link between the grounds - there was some discussion on this back earlier in the thread, about pg 10-15 something like that
Fran
EDIT: my cart is 0.35 and its plenty loud enough with the partridge 977....
Old 25th October 2011, 05:59 PM   #498
Originally Posted by woodturner-fran View Post
See the sch in the pic below:
He ties gnd on the primary side to gnd on the secondary. Salas, I note you didn't do this in your schematics, although there was some discussion about it back a little. Both version of yours are working fine? No need to follow that common gnd?
Made more progress tonight. The transformer box is done, next up is the umbilical from phono box to transformer box. Then I can start on the circuit itself - thanks to the arrival of some nice matched caps from Poros Island......
We will see which is most IMF-affected postal service... I'm already guessing it is the Irish one!
Fran
Originally Posted by Salas View Post
It worked better for hum with the primary floating for ''balanced'' transfer, but it worked both ways.
So better don't have connected both gounds & left floating as per Salas advice.
Did you connect the step-up tx to chassis gnd as pic to avoid hum?
Old 25th October 2011, 06:05 PM   #499
Salas's Avatar
Valve Itch phono
You are quoting my findings from another SUT model. You will see when you will have a properly working phono as for what is best with the 977 and your TT grounding.
Old 25th October 2011, 06:23 PM   #500
That's a good advice as always, I will follow experimenting with my own Itch.
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 27th September 2008 12:49 AM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 09:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 05:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 03:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 03:12 PM
