Valve Itch phono
Valve Itch phono
Old 20th October 2011, 11:07 PM   #481
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
Originally Posted by taniknight View Post
Salas, do I remember correctly that that you pointed out that there will be DC at the input and a blocking cap should be used in the absence of a transformer to protect the cart coil?
Edit: Yep, in post 4.
Usually innocuous, but its advised to check with a DMM on mV DC that there is no appreciable voltage on the input from a leaky valve before hooking up an MM cart straight. Although rare, it could be.
Old 23rd October 2011, 02:28 PM   #482
merlin el mago is offline merlin el mago
merlin el mago's Avatar
1578 tube can be used instead 6SN7? hole plate is better, why?
Old 23rd October 2011, 02:36 PM   #483
Salas's Avatar
Valve Itch phono
Haven't used it ever. There was a thread: Russian 6N8S/1578
Old 23rd October 2011, 04:17 PM   #484
Can I buy 2 MELZ 6N8S / 6SN7 tube metal base (hole plate) for $100.00, it's a good price?
Old 23rd October 2011, 07:16 PM   #485
bobrown14 is offline bobrown14  United States
$50 per tube - you probably wont see them any cheaper these days. Bought a bunch a few years ago for around $40 per but that was a good deal and I was patient and looked for a while. They are the best 6SN7 tubes I've heard and are at least as good as the RCA 5692 rugedized version. As good as they sound, my results varied, a few were microphonic. I stoped looking for them after 2 went microphonic. So I suspect some on the market were rejects from the factory even tho they have the OKT stamp on them. I started buying the 5692 RCAs as they are much more reliable and last virtually forever in audio and sound almost as good, very close 2nd in my gear.
Bob
Old 23rd October 2011, 08:16 PM   #486
On ebay a couple starting from $100 to $174 all metal base but not hole plate, I see a couple very interesting but a little expensive circa $140 but measurement is very good
Thanks,
Felipe
Old 23rd October 2011, 09:22 PM   #487
woodturner-fran is offline woodturner-fran  Ireland
Maybe don't get too caught up in the tube rolling yet - save it for later after you have it up and running and when you're finished with caps etc....
The $100 will bu a lot of the rest of the parts...
Old 23rd October 2011, 10:28 PM   #488
Thanks,
Felipe
Pass on them - THE only 6N8S worthy of that price are the round hole versions.
Bob
Old 24th October 2011, 12:13 PM   #489
Bob
Hey guys,
Thank you very much for your good advices.
Felipe
Old 25th October 2011, 11:27 AM   #490
Default Partridge 977
Just arrived the couple of partridge 977 for the Itch could you help me to wire up, there is 1 red pin, 1 yellow pin & 2 green pins connected, attached pic:
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
