| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#411 |
Thanks for your work Fran
#412 |
Another proposal. I know people may want to try different capacitors for the RIAA section, and you may have your own ideas about what you want. But most will agree that there should be good matching between L&R channels. There are 2 caps involved, 15nf and 47nf.
If prospective builders could get together, it should be possible to get either the seller to match pairs or buy a surplus amount and match them...... There's probably only 3 or 4 people here right now who are building or near building.... but it might be enough. If you could find a russian ebayer with all of the types of caps needed, they might do a deal for a 2% matched pairs of 47nf and 15nf and non-matched sets of the other caps needed for everything else for a single shipping price. Just suggesting it! Fran Last edited by woodturner-fran; 10th August 2011 at 08:28 PM. |
#413 |
That might be a very good idea... I am testing the FT-1 for the 15n placement with outstanding results but all values I got are 15.7n and higher. I wish I could have some 15.1nF and 15.3nF to test.
I do not know if any of the russian suppliers is dependable enough to do such a matching but I will ask. There is another (American) supplier that also provides Teflon caps... Merlin... Can you help ?
RC |
#414 |
Ricardo, ask Marko matched pairs (shop 33Audio).
Site: Surplus USA Film Capacitors Teflon Polycarbonate Polyester Polypropylene E-mail: marko@33audio.com 15$00 USD each Cheers, Felipe |
#416 |
diyAudio Chief Moderator
Those are listed as 100-200V capacitors by majority. Not enough for the Itch. I have warned before.
#417 |
$15 each is very pricey. I would have thought you could get a russian seller to do all the caps for the itch for about that price, maybe plus shipping.
Fran |
#419 | |
, I forgot HV for Itch RIAA, but for 15nF Marko has 0.015uF 10% tol. 400V, TexCap 200GGS.
#420 |
| Got the build itch again. 80w kt88 | itsmejto | Tubes / Valves | 44 | 26th September 2008 11:49 PM |
| valve phono stage wanted for mc | brobarrie | Swap Meet | 1 | 13th August 2007 08:17 PM |
| Basic DIY Valve Phono Stage | matthew2456 | Tubes / Valves | 5 | 29th March 2007 04:11 AM |
| Phono pre, valve or jfet | lndm | Analogue Source | 7 | 4th April 2006 02:11 PM |
| phono preamp design for c3m postie valve | fergs1 | Tubes / Valves | 1 | 29th May 2005 02:12 PM |
