| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#401 |
Silver micas have been snapped by Ian....
Fran |
#402 | |
PSU Itch all resistor 1/4W except: R1 & R4? |
#403 |
Yes, although I cannot see R1 in the two box PSU.....
Note also that the shunt is a separate item.... BOM is almost done, just needs checking. Fran |
#404 |
#405 |
Yikes,
I looked at that 10 times carefully to try and find it and couldn't see it!! Fran |
#406 |
#407 |
I have the BOM ready, and it has already been examined by Salas. Would someone else volunteer to check it out? Let me know by PM if you would do it + your email address and I'll send it on.
Would be nice to get another pair of eyes to look before posting it here. Fran |
#408 |
If you need help with BOM YHPM
#409 |
Cool
I experimented with Silver Micas, PIO, Polystyrene & Tin Foil and now Teflon FT-1 on the 15nF placement and they all produce very different perspectives. I hope I could get the Teflon definiton and extension with the Tin Foil/styrene presence and tone coherence, added with a little bit of SM snap
RC |
#410 |
Hi All,
attached is the BOM for the itch. It covers the valve itch circuit + the PS schematic shown above, i.e. heaters, basic HV but leaves out the actual shunt components. The BOM is an excel type workbook. This first worksheet is the main BOM with links to mouser parts. The other worksheets show the schematics to match the BOM and a SSHV schematic with values to suit the itch current and voltage requirements is included. I have also included a PDF in case someone has no way of reading an excel file. Purely selfishly, I have only done mouser parts as that's who I normally order this kind of stuff from. If someone would like to add digikey and farnell references as well, that would be fantastic. Likewise alternate ebay sellers for the other stuff too. Now the disclaimer!! The BOM has been examined by 3 sets of eyes, mine, Salas and Merlin el Mago - BUT that's not to say there isn't some mistake in there, or indeed that a better choice could be made. So please keep your eyes open and minds active when doing your order!!! Please let us know here if you do find something wrong - it may save hassle for others coming after you. Fran |
| Got the build itch again. 80w kt88 | itsmejto | Tubes / Valves | 44 | 26th September 2008 11:49 PM |
| valve phono stage wanted for mc | brobarrie | Swap Meet | 1 | 13th August 2007 08:17 PM |
| Basic DIY Valve Phono Stage | matthew2456 | Tubes / Valves | 5 | 29th March 2007 04:11 AM |
| Phono pre, valve or jfet | lndm | Analogue Source | 7 | 4th April 2006 02:11 PM |
| phono preamp design for c3m postie valve | fergs1 | Tubes / Valves | 1 | 29th May 2005 02:12 PM |
