Valve Itch phono
Valve Itch phono
Old 19th June 2011, 09:41 PM   #311
woodturner-fran is offline woodturner-fran  Ireland
Only got back to this tonight. I did go back and add in the FT3 as bypasses for the 2.2uF film outputs, but couldn't really detect much of a difference. They can stay though....
Anyway, I went searching for something with a good drum sound, went for my copy of time out.... and there it was - gone! couldn't find it for the life of me!
Anyway, I recorded this snippet. Its Van Morrison at the Grand Opera House, second track side 1, Dweller on the Threshold. This whole album is a bit "brighter" than the one put up earlier, so might give another look at the highs. The track is fairly dynamic, with a fair bit of snap going on.
sample track
Fran
Old 19th June 2011, 10:18 PM   #312
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Valve Itch phono
Quite good from my point of view
Old 19th June 2011, 10:28 PM   #313
Yep!
Bear in mind the lp is an old one, not a fancy reissue.
Fran
Old 19th June 2011, 10:34 PM   #314
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
I will download now to listen also.
Old 19th June 2011, 10:43 PM   #315
nhinstruments
RCruz's Avatar
Valve Itch phono
The older ones are better IMO.
Normally, new ones have lower surface noise but some are reworked reissues based on dat files or other digital medium.
What cap value / type are you using for the 15n in the riaa ?
Old 19th June 2011, 10:45 PM   #316
Salas's Avatar
Valve Itch phono
sample track
Fran
With this record I have no quibbles regarding the tonality, this Itch seems well scratched.
*I checked again my listening position RTA for my PC desktop spkrs the other day. Beyond a room mode from the sub, its balanced enough. Can't hear the 100Hz nowhere as heavy as it looks, you know with subs it takes a room average to see better.
Old 19th June 2011, 10:57 PM   #317
Yes - very clean tone I think. And purely subjectively, its dynamic as hell....
RCruz: K40Y-9 measuring at 15.3nF.
This is what I think:
vinyl nirvana - geddit?
Fran
Old 19th June 2011, 11:03 PM   #318
Salas's Avatar
Valve Itch phono
Did their unplugged on MTV ever got on vinyl BTW? That one was nicely recorded.
Old 19th June 2011, 11:08 PM   #319
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Very cool!
I'll be spinning my (black) copy later I think. Love the meaty bass on Lithium.
Your latest clip is very good BTW.
jeff
Old 19th June 2011, 11:32 PM   #320
Salas's Avatar
Valve Itch phono
jeff
Indeed, now I miss no ''sparkle''. Maybe its the Zoom H2 he got now also more accurate over the H1 he had for the other tracks.
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
Copyright ©1999-2017 diyAudio
