Valve Itch phono
Valve Itch phono
Old 25th May 2010, 02:21 AM   #11
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
Originally Posted by RCruz View Post
I Salas
Is there a thread on the bench ?
Kofi Annan in: "Cascodin' with Steve Bench's RIAA!"
Old 25th May 2010, 02:58 AM   #12
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I like that low impedance RIAA. I was never comfortable with very high impedance circuits.
Why do you not use a cathode resistor at the input ? Noise ? Some lokal degeneration could improve TDH. Some second harmonic can sound very attractive though. I learned that when i build the PSG buffer. Another option whould be to put the transformer in the cathode.
Old 25th May 2010, 10:11 AM   #13
Salas's Avatar
Valve Itch phono
Yes, noise. Interestingly after a year I made it, I read Vogel's silence and he is pointing out the SRPP & mu topologies and no grid resistor as best for noise. He he, nice. I would think about just an IR LED the most on cathode. The THD probably comes from driving the 22K from the high rp follower upper section though... Paralleling 2 sections up & down the mu would do better for noise and drive, those 6N2PEV are not costly. A tube like E810F trioded or D3A would be best noise wise. I just had the Russians and tested. I got surprised by the non existent microphony from those.
6N2P
Old 25th May 2010, 12:36 PM   #14
Allen Wright is offline Allen Wright  Switzerland
R.I.P.
[QUOTE=Salas;2197581]Those 1.4 & 4mA on the schematic are actually measured as far as I recall but could have made a typo as well. /QUOTE]
Doesn't make sense to me.
You have the first tube without any cathode R, yet get 1.4mA. The second tube has substantial cathode bias yet you get three times as much current at 4mA. And in both cases the bias R on the upper tube is the same.
Regards, Allen
Old 25th May 2010, 12:45 PM   #15
Salas's Avatar
Valve Itch phono
Don't remember, really. I have to get it back or visit the friend I gave it to and see again the drop on 1st stage RC filter's 3k3 inline with PSU. Maybe I mixed something back then and noted those numbers. Second tube is different, its 6H8/6SN7.
Old 25th May 2010, 12:52 PM   #16
cjcc67 is offline cjcc67  Australia
Salas,
i now have three itch!! 1.simple pre pre 2 simple riaa, 3 Allens FVP5 and this one!! Better get scratchin'!!
Old 25th May 2010, 12:54 PM   #17
Salas's Avatar
Valve Itch phono
Old 25th May 2010, 04:49 PM   #18
Salas's Avatar
Valve Itch phono
Got intrigued and since I haven't got it in hand to measure the first stage current, I made a simulation on LT Spice. I used a 12AX7 model which is not far from 6N2 just to be in the ballpark. It roughly follows that 1.4 mA first stage schematic note.
Old 16th September 2010, 07:01 AM   #19
Dogie_Hogan is offline Dogie_Hogan  Netherlands
Dogie_Hogan's Avatar
All octal tubes: the 6SL7 in stead of the 6N2P?
Old 27th September 2010, 04:00 AM   #20
Salas's Avatar
Valve Itch phono
Sorry for the late reply. Haven't tried anything different there. The first stage is based enough on the characteristics of the cheap Russian tube though. If you want to make an experiment with 6SL7 you are welcome.
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 27th September 2008 12:49 AM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 09:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 05:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 03:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 03:12 PM
