Valve Itch phono - Page 193 - diyAudio
Old 22nd May 2014, 10:49 AM   #1921
stajo is online now stajo  Sweden
I would say it probably needs some counting, testing and tuning. White CF is hard to make sound good imho.
Old 22nd May 2014, 01:17 PM   #1922
merlin el mago's Avatar
Thanks for the info.
Old 2nd October 2014, 08:14 AM   #1923
I measured the capacitance of the phono cable between the Itch & the #26 and measures 500pF (3 meters long), have I to increase the C of the Zobel step-up Jensen to 200pF?
Attached pic just for fun of increased mass of Linn Ekos tonearm, now Itch + Denon DL103R plays in other league.
Old 2nd October 2014, 09:08 AM   #1924
Oooops my mistake have I to reduce to 100pF?
Old 2nd October 2014, 11:11 AM   #1925
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The SUT secondary termination (Zobel) is a different matter regarding the output of the full circuit. That Jensen could be fairly well compensated for square waves with 100-150pF in the Zobel too, at least on the oscilloscope tests I have shown before on my samples. You could try those values too for subjective impact.
The Itch output comes from a low impedance point (from the cathode follower part of the Mu circuit) and it can drive some cable capacitance. Its a 6mA 800 Ohm source with the 6SN7 in the V1.2.
Old 2nd October 2014, 11:29 AM   #1926
"The Itch output comes from a low impedance point (from the cathode follower part of the Mu circuit) and it can drive some cable capacitance. Its a 6mA 800 Ohm source with the 6SN7 in the V1.2."
Could you post a pic?
Old 2nd October 2014, 11:41 AM   #1927
Salas's Avatar
Nothing different. As the output stage values in the V1.2 Valve Itch phono
Old 2nd October 2014, 12:41 PM   #1928
So I only have to change: R9-11 now 330R and R10 now 12K 2W?
Old 2nd October 2014, 12:54 PM   #1929
Salas's Avatar
Yes, only the resistor values. The circuit topology is the same from the start.
Old 2nd October 2014, 01:04 PM   #1930
I have Kiwame 330R but I don't have 12K 2W
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
Copyright 1999-2017 diyAudio
