Valve Itch phono
Valve Itch phono
Old 1st February 2014, 10:01 PM   #1561
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
Default This is revision 1.2
Audio circuit rework. Mainly values.
All peripheral circuits remain the same.
THD at about 0.03% on nominal cart level, 2nd harmonic only.
Noise down to -86dBV@30Hz unweighted depending on input valve sample.
No perceptible harmonic noise when the SUT has a balanced primary and the cartridge is wired floating to it.
Only wide band random noise.
Curve is +/- 0.2dB 100Hz-15kHz including the SUT aberrations when R5,R6,C2,C3 are hand picked. R5=100K//100K. C3=15nF//750pF.
Suitable also for HOMC & MM sans SUT. Input overload: Beyond my oscilloscope's vertical capability at times 1.
Subjective impressions are enhanced vs. older version realizations.
Old 2nd February 2014, 06:59 AM   #1562
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Valve Itch phono
That's good news!
Is there a chance for a PCB in the future?
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 2nd February 2014, 09:10 AM   #1563
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Great, 2dBs more can help to use my 1:6 Partridge 977 step-up with my mod Denon DL103R
Old 2nd February 2014, 09:44 AM   #1564
I have several questions:
-R2 18K 1W?
-For R11 I have Kiwame 2W and Shinkoh 1/2W, wich one do you prefer carbon or tantalum?
-In place of LD1 infrared I have 1N4148, is ok or have I to change for 1,9V-2V red LED?
TIA
Old 2nd February 2014, 09:58 AM   #1565
Salas's Avatar
Valve Itch phono
-R2 1/4W
-Tant R9 R11
-Infrared only
Old 2nd February 2014, 10:03 AM   #1566
Wich one?
LEDs IR
Old 2nd February 2014, 10:12 AM   #1567
Salas's Avatar
Valve Itch phono
HIRL5020
Old 2nd February 2014, 10:14 AM   #1568
Many thanks
Old 2nd February 2014, 10:16 AM   #1569
Did you use the infrared as power on/off indicator?
BTW nice PC speakers
Old 2nd February 2014, 10:24 AM   #1570
Salas's Avatar
Valve Itch phono
He, he humor. It does not show any light to the human eye, its used for 1V bias @ 1mA.
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
