Valve Itch phono - Page 149 - diyAudio
Old 27th September 2013, 08:52 PM   #1481
merlin el mago's Avatar
One Spanish vacuum tube seller told me a 6N8S criogenically treated sound better than an 1578 6H8C metal base hole plates!!!
Old 27th September 2013, 08:53 PM   #1482
Originally Posted by RCruz View Post
SQ ?
What is it ?
Sound Quality
Old 27th September 2013, 08:56 PM   #1483
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Thank you Merlin.... I should know better by now.
RC
Old 27th September 2013, 08:59 PM   #1484
You are always welcome Ricardo.
Old 27th September 2013, 09:01 PM   #1485
RCruz's Avatar
RC
Old 23rd October 2013, 09:38 PM   #1486
stajo is offline stajo  Sweden
So how you guys feel about an integrated version with the 6V6 pre? Selector and pot infront of R17 and an SSHV on 50-55 mA as source per channel. Just a starterschetch.
Old 24th October 2013, 11:58 AM   #1487
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Integration is deleting the phono to pre interconnect so there is a benefit. It could be more challenging for doing everything properly not to catch any noises OTOH.
Old 24th October 2013, 12:31 PM   #1488
The idea came up merely because physical chassiework etc is a DIY factor that takes time and effort for most people when doing it properly and the powerline is a cost factor. When thinking of building 2 x 2 chassie+external psu, together with eventual microphonic sensitivity on the 6V6 that might take extra care in chassiework, it seemed like a decent idea.
What do you think of the powerline in this case, SSHV with following RCs?
Old 24th October 2013, 01:17 PM   #1489
Salas's Avatar
It will work satisfactorily I guess since the μ follower shows good psrr so not to get easily affected by other stronger stages.
Old 24th October 2013, 02:00 PM   #1490
I was tinkering about the size of C6, 2,2 uF. It seems large for me related to sufficient bass response in this context. Is there any other particular reason for the choice of this?
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 27th September 2008 12:49 AM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 09:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 05:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 03:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 03:12 PM
Copyright 1999-2017 diyAudio
