Valve Itch phono
Valve Itch phono
Old 21st September 2013, 02:21 PM   #1451
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
BTW maybe 1N4148 diodes which are small current and very low capacitance can be best bet there for lifting the cathodes.
Old 21st September 2013, 02:25 PM   #1452
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by Salas View Post
Nice that you repaired it Merlin. Well done. Can you hear the rough supply's hum or buzz at all or the circuit rejects it enough?
As you said the circuit rejects it enough
Old 21st September 2013, 02:27 PM   #1453
Salas if is not to ask too much could you suggest a 3rd stage to have moe gain, I'm very pleased with the SQ of Partridge 977 only that I need more gain.
Old 21st September 2013, 02:36 PM   #1454
Next Monday I will ask to my local supplier, thanks for the trick.
Old 21st September 2013, 02:47 PM   #1455
Salas's Avatar
Valve Itch phono
Hmm it will reverse absolute polarity if its only one tube. If you will use an adapter for 6DJ8 / ECC88/ 6922/7308 in the second stage it will give +4dB over the 6SN7 without adding stages BTW.
Old 21st September 2013, 02:53 PM   #1456
Itch 42dB + 4dB ECC88 = 46dB + 15,6dB Partrdige 977 = 61dB, can be enough for 0,25mV DL103R?
Old 21st September 2013, 02:56 PM   #1457
Salas's Avatar
Valve Itch phono
I used 61dB before for that cart with DCB1 and 30dB amp and it was alright on 90dB+ speakers. But its subjective also about what you and me feels "loud" enough.
What impedance line input you drive now with the Itch? Maybe you lose some signal on low impedance volume pot line preamp also that 6SN7 can't drive strongly?
Old 21st September 2013, 03:01 PM   #1458
I use the Itch with:
-ECC81 mu-follower, 100k input pot (headphone amp for Sennhs HD600)
-#26 preamp, 100k input pot (lineamp)
Old 21st September 2013, 03:13 PM   #1459
Salas's Avatar
Valve Itch phono
No problem with loading the 6SN7 too much.
Old 21st September 2013, 03:15 PM   #1460
How can loading much the 6SN7: changing the pot for another with more ohms?
Have I to change something or simply buy a couple of adapters 6SN7-ECC88?
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
