Valve Itch phono
Valve Itch phono
Old 17th September 2013, 07:20 PM   #1441
merlin el mago is offline merlin el mago
merlin el mago's Avatar
I swapped the tubes but the situation doesn't changed....
Old 17th September 2013, 07:23 PM   #1442
stajo is offline stajo  Sweden
Valve Itch phono
Then I would first check so pin 3 (kathode) is to ground and measure voltage on pin 1 anode. If all ok then disconnect R5 from V3 pin 3 kathode and measure again.
Old 17th September 2013, 07:26 PM   #1443
Oooooops stajo & Salas diode connected the negative side to V1 pin 3
I'm not justifiying but the strong light that I use caused my big mistake....
Old 17th September 2013, 07:30 PM   #1444
Valve Itch phono
Thats a show(current)-stopper
But I checked some pages ago. Didnt you say channel was down also Before you put diodes there?
Old 17th September 2013, 07:43 PM   #1445
Now both channels amplifies the signal, time to connect
Old 17th September 2013, 07:47 PM   #1446
Thanks for support, the story it's a little bit long: this morning I discovered that grounded heaters was not well connected & tonight the reversed diode, I'm an electronic CRACK
Old 18th September 2013, 02:28 PM   #1447
Valve Itch phono
So how does it sound Merlin?
Old 18th September 2013, 02:50 PM   #1448
Thanks for your interest but still I don't know, I have a very busy day!!!!!!! I will let you know.
Old 21st September 2013, 01:10 PM   #1449
First I used the same reversed diode but no sound left channel, chenged for a new diode and now both channels sounds OK, but my Denon DL103R needs more gain isn't enough Partrdige 977 1:6 so I have to change for a new MC step-up 1:10 or more....
Old 21st September 2013, 02:18 PM   #1450
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
Nice that you repaired it Merlin. Well done. Can you hear the rough supply's hum or buzz at all or the circuit rejects it enough?
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
