Valve Itch phono
Valve Itch phono
Old 13th August 2013, 05:13 PM   #1221
stajo is offline stajo  Sweden
Valve Itch phono
By setting delay and measuring time you can "zoom" into the startup phase to look for if the caps are sucking energy from the transformer that starts ringings.
I dont see any such tendencies here. Of course this has to do with many factors like the speed and size of caps etc. Inductors in the filter chain can also start interfere with caps and trannys in a bad way to show this edgy behaviour under startup.
Snubbers can be good but its very hard to test them out. There is no "one size fits all" value there. So if you cant test them out leave them out. They can certainly cause more harm then good.
Old 13th August 2013, 05:21 PM   #1222
merlin el mago is offline merlin el mago
merlin el mago's Avatar
I ont' understand why the voltage at the load varies depending the ms and the delay?
Old 13th August 2013, 05:30 PM   #1223
Valve Itch phono
I presume that you by "voltage at the load" meen V(I1) in this case. It shows minimum value and maximum value over the voltage over load (I1). Third column "Diff" is "Max minus Min voltage over load".
If you set the measurment with a delay long enough so caps has charged and startup phase is over then "Diff" is "ripple under run".
If you set it with no delay "Diff" is "Zero to Max voltage" which is not very interesting if youre looking for ripple.
Does that make sense?
Old 13th August 2013, 05:39 PM   #1224
Yes I wanna say V(l1) as voltage at the load.
Diff is only ripple at the start up or is continous ripple when run?
Old 13th August 2013, 06:07 PM   #1225
Valve Itch phono
I made some pix for you. Maybe those say more then words. Look at measured time and delay at every picture and how the curves and measures change.
Its all the same circuit, just different measuring time and delay.
Old 13th August 2013, 06:21 PM   #1226
Thanks for your work
Old 13th August 2013, 06:46 PM   #1227
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Valve Itch phono
Hi Merlin
I remember you placed some small caps in the inputs of your itch... why ?
RC
Old 13th August 2013, 06:47 PM   #1228
10nF between signal an ground to avoid antenna efect caused by the cables.
Old 13th August 2013, 06:50 PM   #1229
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
Maybe between RCA ring and chassis?
Old 13th August 2013, 06:59 PM   #1230
Actually I don't have any cap connected because the Itch runs dead like a tomb
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
