Old 15th April 2011, 12:14 AM   #111
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Since I haven't seen it working with stringed heaters, I can't speak from experience. Gibson had used them in parallel for one. I would prefer you don't mix stages heaters if possible for this kind of gain app.
Old 15th April 2011, 12:27 AM   #112
Sure - thats easy. I have some 15V transformers - which would suit ~12V heater supplies..... can use different secondaries for each, or even separate transformers. BTW, anyone looking for some - farnell still ahve some a ~€3 each!
Fran
Old 15th April 2011, 12:33 AM   #113
Salas's Avatar
You need two envelopes, one noval, one octal, at 1/2B+ elevated heaters for covering two channels in this phono. Another two the same at no elevation. Plan clear.
Old 16th April 2011, 12:32 PM   #114
Valves and bases ordered today. Traffos in stock - just need to organise the parts list next....
Old 16th April 2011, 12:45 PM   #115
Salas's Avatar
Lets see who does the first one. We have early British & Australian interest but Irish outsider late entry may steal the contest.
Old 16th April 2011, 02:16 PM   #116
Hah!! at the rate I'm going I really will be paddy last!
Anyway, giving back to community!!
BOM with mouser links.
PS info not included, wima caps chosen as reasonable base to start from, circuit numbered to match my own notes, prices are +vat.
Please double check!!!!
Fran
Old 16th April 2011, 03:04 PM   #117
Salas's Avatar
Fran
I would advise against the interstage coupling cap to be a Wima if possible. See for USSR K40Y PIO or 0.047uF K72P Teflon. Boutique PIO and Teflon no problem but can set back the budget heavily...
Old 16th April 2011, 03:08 PM   #118
Yes, I'd agree - i'll add a note to say that k40y will sound better....
Would you suggest the same for output cap and RIAA ones?
Old 16th April 2011, 03:42 PM   #119
Salas's Avatar
For Riaa such caps lack in tolerance. For output I prefer 2u2 and to pre-shape the LF roll off with the interstage so it can mate many line inputs, still holding a determined rate fall. 47n to 100n interstage OK. 2u2 difficult in CCCP caps. Maybe K75-10 500B 1u//1u // FT3 0.1u. Green monstrosity with a silver accent.
Old 16th April 2011, 06:40 PM   #120
Yes, I've heard that before - but it might be worth buying a number and matching by hand.
Anyway, I've found a russian federation seller on ebay and will be ordering from him.....
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
Copyright ©1999-2013 diyAudio
