Valve Itch phono - Page 115 - diyAudio
Old 24th February 2013, 07:00 PM   #1141
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Noise.
Old 24th February 2013, 07:14 PM   #1142
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Perfect.
So if I get it correctly, grounding the lower tube cathode, bias the grid at 0 volts so the triode is fully open and working at max current. You dose the current with the upper ccs so there is no overdrive even if the signal goes positive.
RC
Old 22nd March 2013, 01:10 PM   #1143
Salas's Avatar
Originally Posted by cygnus x1 View Post
I was never a big fan of 6SN7 (but I have not heard a 1578melz)
Interesting what I read today:
"The μ-follower proved to be an excellent test bed for determining the irreducible distortion of a valve.....Surprisingly, given its good reputation, the 76 did not measure particularly well...One triode was significantly better than the others...this valve is the 6SN7, 12SN7, 7N7, 14N7 or 6J5."
VALVE AMPLIFIERS FOURTH EDITION - MORGAN JONES (page 618).
So there we are, it wasn't a bad choice for Itch's 2nd μ stage.
Old 23rd March 2013, 08:53 PM   #1144
neskor is online now neskor  Serbia
Today I build Valve Itch phono with spare parts, just for fun.
But unfortunately sound is not really good, like covered with blanket.
Strange thing happens when I switch off power supply, sound suddenly become clear and good. Same thing happen when I switch on power supply, first couple of second sound is clear but after that sound again become dull.
Tried different power supply but same thing
Any clue?
Old 23rd March 2013, 09:22 PM   #1145
Salas's Avatar
Not normal. What types of PSU? Can you scope the rail during those on/off cycles?
Old 23rd March 2013, 09:26 PM   #1146
Unfortunately I don't have oscilloscope.
PSU is just plain, build in 5 min. gretz, capacitors and resistor, no Salas HV
Old 23rd March 2013, 09:34 PM   #1147
Salas's Avatar
Can you measure the DC voltages of all tubes from plate to ground after 5 minutes you turn it on? So we see how it biases first. Do you use some SUT and MC cartridge? Having any hum?
Old 23rd March 2013, 09:43 PM   #1148
No hum at all
Right now no MC or SUT, just playing ordinary MM catridge.
All voltages are good, checked several times.
Old 23rd March 2013, 09:51 PM   #1149
Salas's Avatar
Maybe you got some DC offset on the input? What tube you use on input?
Old 23rd March 2013, 10:06 PM   #1150
input tube is 6n2p-ev
checked again, so voltages are:
from top 6n2p, anode is on 270V, cathode 187V, anode bottom 6n2p is 77V, grid on - 0.4V.
from top 6sn7, anode is on 310V, cathode 185V, anode of bottom 6sn7 is 78V and cathode is 1,8V
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
Copyright 1999-2017 diyAudio
