Valve Itch phono - Page 114 - diyAudio
Old 24th February 2013, 05:54 PM   #1131
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by RCruz View Post
Hi Salas
I am now studying the Itch and allready have some basic questions:
In the first stage you use a rather highish plate resistor for the lower triode (R2 = 82k) and I believe you do so because you do not need a large voltage swing on the output of that mu stage.
Anyway, the dynamic impedance of that resistor should be around R2 / (1 - Avcf)
What value should I consider for Avcf (Voltage gain of the CF on top?)
Around 0.9 ?
Acts as a current source the top part. Increases gain and PSRR. The first stage has high mu and high rp so it gets a highish plate load for linearity in low swing even, because it lacks cathode degeneration for absolute minimum en (input noise equivalent) reasons avoiding electrolytic decoupling also.
Old 24th February 2013, 05:58 PM   #1132
merlin el mago's Avatar
What about the lesson Ricardo? I'm trying also to learn meanwhile I enjoy my Itch
Old 24th February 2013, 05:58 PM   #1133
Salas's Avatar
Second question:
I see you ground V1 V2 filament heater supply but you bias V3 V4 filament supply at half B+... why ?
The upper half would violate its cathode to heater max spec if done otherwise.
Old 24th February 2013, 06:11 PM   #1134
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
I understand the top tube acts like a ccs so the lower tube sees a much larger dynamic plate resistance and that makes it more linear ok
Thank you for the filament explaining... I was not aware of the cathode to heater max spec.
Now, please indulge my lack of knowledge.... I am starting to understand tubes now but still do not know how to bias a triode... I did not know oine could make Vgrid = Vcathode =0 and make it work like a fet at Idss ....
Would you please enlighten me ?
RC
Old 24th February 2013, 06:24 PM   #1135
Salas's Avatar
Its not like that. The current forced through as fixed in the upper part makes it bias. The valve type should be carefully selected here to be linear enough at low current and having minimal grid leakage. Batch quality can be easier to detect in such "naked" bias arrangement in high gain input position. Maybe Fellipe had felt that subjectively when choosing input valves.
Old 24th February 2013, 06:26 PM   #1136
Yes Salas big improvement using very good input valves.
N.B. Have you in mind to desgin a tube headphone amp for high Z headphones?
Old 24th February 2013, 06:30 PM   #1137
Salas's Avatar
Maybe if I get other than Grado that I have.
Old 24th February 2013, 06:31 PM   #1138
Erno Borbely likes the Grados and I love my Sennhs HD600
If I owned Grados didn't look for headphones amps: I have Erno Borbely balanced lineamp....
Old 24th February 2013, 06:39 PM   #1139
You are welcome to Sennhs HD600
Old 24th February 2013, 06:48 PM   #1140
nhinstruments
RCruz's Avatar
Thank you again... I was not understanding how a triode without negative grid bias could cope with positive signal overdrive correctly.
Now another question.... It seems penthodes make much better CCS than triodes.... why did you choose a triode for the upper CF ?
RC
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
Copyright 1999-2017 diyAudio
