Valve Itch phono
Valve Itch phono
Old 22nd February 2013, 05:04 PM   #1121
merlin el mago is offline merlin el mago
merlin el mago's Avatar
What's the output voltage of your Audioquest Onyx LOMC? I suspect can be enough with your 1:10 SUT & Itch.
Old 22nd February 2013, 05:26 PM   #1122
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
Originally Posted by cygnus x1 View Post
I'm using an Audioquest Onyx LOMC, and currently running it through a set of vintage Shure SUT 1:10 (which I like a lot). Arm is a Sumiko Premier MMT on a modified VPI HW 19 MKIII w/outboard motor. So far I have been happy with a Siren Song, SB cascode 12AY7, and a Salas NJFet RIAA w/SSHV reg (thanks Salas for the great designs). Both the Siren Song and NJFet are really quiet.
The Itch along the 1:10 SUT should suffice for gain even if your cart is 0.2mV to 0.3mV. Already having a line preamp with some gain presumed.
Old 22nd February 2013, 05:29 PM   #1123
My cart is 0.25mV togheter my SUT is 1:6 are enough for Itch.
Old 22nd February 2013, 06:00 PM   #1124
cygnus x1 is offline cygnus x1  United States
I had a hard time finding any info on it. All I know it is close to a Audioquest AQB100MH, which is listed as 1.6mv (was built by Scantech and rebranded and labeled for the US). I do think that the rated output is correct for the Onyx. It's no more that 2mv. Yes I do have a line stage, a 26 5:1 xfmr coupled.
Old 22nd February 2013, 06:07 PM   #1125
Salas's Avatar
Valve Itch phono
You will see how it best matches when you will have it built then.
Old 22nd February 2013, 06:07 PM   #1126
I didn't find any info of your cart, AQB100MH have load impedance 47K is the same like your Onix?
Old 24th February 2013, 05:12 PM   #1127
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Valve Itch phono
Hi Salas
I am now studying the Itch and allready have some basic questions:
In the first stage you use a rather highish plate resistor for the lower triode (R2 = 82k) and I believe you do so because you do not need a large voltage swing on the output of that mu stage.
Anyway, the dynamic impedance of that resistor should be around R2 / (1 - Avcf)
What value should I consider for Avcf (Voltage gain of the CF on top?)
Around 0.9 ?
RC
Old 24th February 2013, 05:16 PM   #1128
nhinstruments
RCruz's Avatar
Valve Itch phono
Second question:
I see you ground V1 V2 filament heater supply but you bias V3 V4 filament supply at half B+... why ?
RC
Old 24th February 2013, 05:18 PM   #1129
I think so, that's the way I have it loaded through my SUT.
BTW, I did a search through all my schematics I've archived over the years, and found a very similar circuit to the itch. I was by the late great N. Shishido, published in MJ mag in the 80's and later republished in Sound Practices. Dual 6DJ8 with a passive Tango LCR riaa between stages and 1:10/20/40 Tango SUT input. The 6N1p input and the SSHV should really make this itch circuit sing (very clever Salas).
Old 24th February 2013, 05:41 PM   #1130
Salas's Avatar
Valve Itch phono
What you may learn...Shishido had done alike is pretty nice. I would never use same amount gain stages, the BGs, the high bias commanded for driving the LCR, and the stoppers though. I am confident the Itch is 10dB better for noise by implementing the head amp concept and possibly has more accurate EQ.
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
