Valve Itch phono
Valve Itch phono
Old 9th February 2013, 10:06 AM   #1111
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
Hvala.
Old 9th February 2013, 10:07 AM   #1112
neskor is offline neskor  Serbia
Originally Posted by Salas View Post
Hvala.
Old 9th February 2013, 10:13 AM   #1113
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Valve Itch phono
wakoo's
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 18th February 2013, 03:10 PM   #1114
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Salas to power the Valve Itch could I use CCS+Gyrator in place of SSHV2?
Old 18th February 2013, 03:38 PM   #1115
Salas's Avatar
Valve Itch phono
You probably can, I don't know what happens because I had never tested with such and the Itch.
Old 18th February 2013, 03:41 PM   #1116
Thank you.
Old 22nd February 2013, 03:28 PM   #1117
cygnus x1 is offline cygnus x1  United States
While I’m waiting for parts to arrive, I wondered what could be done to get more gain, for those of us with LOMC? I was never a big fan of 6SN7 (but I have not heard a 1578melz), but I know I like the sound of 6N1P (when fired up) and 6N23P. Both of these have a higher gain and many give me the gain I need, plus the 6N23P would have lower noise. I know the 6N1P has a plate voltage limitation, so maybe the 6N23P would be a better choice? Would anyone like to try to redesign the circuit for it?
Old 22nd February 2013, 03:32 PM   #1118
Why don't use step-up, wich cart do you have?
Old 22nd February 2013, 04:36 PM   #1119
Salas's Avatar
Valve Itch phono
Make it as is and use a proper SUT. Changing valves and boosting gain without disturbing the SNR is impossible. Known tonal qualities of other valves in other gain builds lose relevance when the signal is competed by input noise in a phono preamp. The total noise is governed by the input stage in the Itch. You can use some adequate tube in the second stage for some more gain since the signal is already linear there after the passive RIAA but if you reach more than 50dB total then the 2nd stage will start contributing. And that is not enough for LMC. Listen to it as recommended first is my 2C.
Old 22nd February 2013, 04:59 PM   #1120
Yea, I kinda wondered if the 6N23P would change the design to much, and sacrifice the SNR and sonic "color" as designed. I'll just have to wait for parts to show up and build as is. I do have a set of RCA red plate 6SN7, that I plan to use.
I'm using an Audioquest Onyx LOMC, and currently running it through a set of vintage Shure SUT 1:10 (which I like a lot). Arm is a Sumiko Premier MMT on a modified VPI HW 19 MKIII w/outboard motor. So far I have been happy with a Siren Song, SB cascode 12AY7, and a Salas NJFet RIAA w/SSHV reg (thanks Salas for the great designs). Both the Siren Song and NJFet are really quiet.
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
