Valve Itch phono
Valve Itch phono
Old 6th February 2013, 06:44 PM   #1101
cygnus x1 is offline cygnus x1  United States
I have been following this thread, so I have to ask, for those of you who have built it, how does it compare to the Steve Bench 12AY7?
Old 6th February 2013, 06:47 PM   #1102
merlin el mago is offline merlin el mago
merlin el mago's Avatar
I can't compare never owned the Steve Bench 12AY7.
Old 6th February 2013, 07:02 PM   #1103
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
That 12AY7 cascode was what a mate had. It was best to all other tube phonos he had made, they were several well known schematics. But he sold it soon after he had made the Itch.
Old 7th February 2013, 10:22 AM   #1104
massimo is offline massimo  Italy
Enough said!
Old 7th February 2013, 10:24 AM   #1105
Each day I like more the Valve Itch.
Old 7th February 2013, 07:56 PM   #1106
neskor is offline neskor  Serbia
In which post is final schematic for Itch?
Old 8th February 2013, 01:22 PM   #1107
OK. I guess I need to build another tube preamp (I have the 12AY7 cascode and a Siren Song). So time to order parts. Is the value for the coupling cap between first and second stage correct, 47nF? Seems a little small. Also is there a schematic for the version used SSHV for this design?
Old 9th February 2013, 09:56 AM   #1108
Salas's Avatar
Valve Itch phono
#391 and #410
Old 9th February 2013, 09:59 AM   #1109
Salas's Avatar
Valve Itch phono
47nF is correct. Gives opportunity for NOS small Teflon. There is high enough impedance to couple to. Can go up to 0.1uF with somewhat less VLF roll off control.
Old 9th February 2013, 10:00 AM   #1110
Thanks Salas!
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
