Valve Itch phono - Page 11 - diyAudio
Old 10th April 2011, 05:37 PM   #101
The Space Egg Corp's Avatar
Hi again Tani
Just another thought.
Don't like multi output LV transformers myself.
Personaly I always go for dual winding toroids or R-cores if you can get them.
R-cores would be 'super cool' IMO for the 'Itch'.
ie. 120-0 + 120-0v / 9-0 + 9-0v
You then have the option of seperate heater windings. Series or parallel connection.
I now habitualy wire stuff for dual UK/USA voltage as well, As I might emigrate to NYC one day !
Cheers
Simon
Old 12th April 2011, 09:56 AM   #102
hesener is offline hesener  Germany
Hi Simon and Tani,
the ratio of 1.41 (sine to rectified) is true for unloaded outputs. Using a 100VA transformer for a 40mA load shouldnt cause a lot of loss, though. If you were to use a 10VA transformer you would see that voltage drop considerably.
Small trick, when connecting transformers back to back you may want to put a foil cap of some microfarads in parallel with the middle connection, this will be quite effective in removing noise coming in from the grid.... less work for the regulator...
Old 12th April 2011, 01:00 PM   #103
taniknight's Avatar
Excellent lessons everyone, many thanks.
I am not shooting for optimal components right now as I have my fingers in many DIY pies. I'm aiming to get something that works well without too much sacrifice on quality, so that I may assess the virtues of each bit of kit and figure out which I like best and focus on those. I think I'll try back-to-back Tx's to get it up and running, then go from there.
I looked at R-cores and found some that were suitable, as were other torroids, though with the cost of postage to Australia, this would be the type of thing I'd install on a final build. I've saved spending on oil caps and the like for the same reason... I feel like I can put faith in a circuit that sounds good with decent yet modest components... then add to it later for the icing on the cake.
With all of your input I feel like I have enough knowledge to proceed... thanks again.
Tani.
Old 14th April 2011, 01:51 AM   #104
Thinking pretty hard about building this.... need to gather a few parts...... starting with a pair of those partridge transformers mentioned earlier....
Next up is to put together a parts list.
Old 14th April 2011, 01:55 AM   #105
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Nice to know. I hope you will like it. Had made valves projects before?
Old 14th April 2011, 02:02 AM   #106
Yes, I have a few - but not phono. Few EL84 amps, and refurbished a KT66. Made a few aikido preamps as well.
I have a pearl with lundahl step-ups and I just think that a valve phono with some step ups could be a very nice compliment to the system. I'm using a benz L2 and a zyx R50.....
Plan on doing the SSHV supply (need 2 actually, one for this and one for a 6SN7 aikido). Have the parts for that, just need some time at the bench!
Fran
Old 14th April 2011, 02:21 AM   #107
Salas's Avatar
OK, you are experienced. Nice to be hearing back when starting with it.
Old 14th April 2011, 01:37 PM   #108
Do you see any issues with wiring the heaters in series and using a 12v supply?
Old 14th April 2011, 10:58 PM   #109
Salas's Avatar
Theoretically no. If stringing the heaters of the same elevation valves won't introduce any noise to the sensitive input signal ones will show in practice. Those Russian input tubes have proved very well constructed and quiet non the less.
Old 15th April 2011, 12:53 AM   #110
Thanks,
I've seen some say that 6SN7s are not suited to wiring in series (although my aikido has them in series and its quiet). Just thought I'd check had you come across this - may be important in as sensitive a case as this.
I'm working through the list of parts, hope to have an xls file over the next few days with mouser numbers.
Fran
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 27th September 2008 12:49 AM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 09:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 05:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 03:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 03:12 PM
Copyright 1999-2017 diyAudio
