Valve Itch phono - Page 103 - diyAudio
Old 6th November 2012, 04:32 PM   #1021
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
That is weird it should read 10 Ohm. Puts Q2 into suspicion.
Old 6th November 2012, 04:35 PM   #1022
merlin el mago's Avatar
Once desoldered how can know if is damaged or if it's OK?
Old 6th November 2012, 04:37 PM   #1023
Salas's Avatar
When powered see what Vgs it shows between its outer pins first.
Old 6th November 2012, 04:38 PM   #1024
Ok I power & measure before I desolder.
Old 6th November 2012, 04:39 PM   #1025
Salas's Avatar
Don't desolder before we agree to.
Old 6th November 2012, 04:40 PM   #1026
0.154 V, have much have to be?
Old 6th November 2012, 04:44 PM   #1027
Salas's Avatar
Its datasheet says 1.5 to 3.5V
Old 6th November 2012, 04:46 PM   #1028
OK I will change, there is a way to know if is OK once desoldered?
Old 6th November 2012, 04:50 PM   #1029
Salas's Avatar
How to Test MOSFET Transistors | eHow.com
Q2 is depletion mode N type.
Old 6th November 2012, 05:17 PM   #1030
Salas I asked because I haven't new spare of DN2540, I have a couple used that I'm not sure if are good, I will do the test and seems once is OK so I will change.
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 27th September 2008 12:49 AM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 09:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 05:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 03:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 03:12 PM
Copyright 1999-2017 diyAudio
