Valve Itch phono
Valve Itch phono
Old 6th November 2012, 02:58 PM   #1011
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
*When its off and soldering see with the ohm meter that C1 shows no short also.
Old 6th November 2012, 02:59 PM   #1012
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Soldered in parallel other 47R, now TP measures 4,3mA see pic
Old 6th November 2012, 03:04 PM   #1013
Isn't short.
Old 6th November 2012, 03:11 PM   #1014
Salas's Avatar
Valve Itch phono
I wonder how it holds regulation with so little apparent CCS current. Is the sink totally cold?
Old 6th November 2012, 03:13 PM   #1015
Let me power on again, but I remember always cold.
Old 6th November 2012, 03:14 PM   #1016
Salas's Avatar
Valve Itch phono
Don't power it. It looks like needing lower resistance.
Old 6th November 2012, 03:15 PM   #1017
Salas's Avatar
Valve Itch phono
Measure TP in resistance mode. What is the reading?
Old 6th November 2012, 03:16 PM   #1018
powered?
Old 6th November 2012, 03:17 PM   #1019
Salas's Avatar
Valve Itch phono
No, off for now.
Old 6th November 2012, 03:22 PM   #1020
7R4
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
