Valve Itch phono - Page 101 - diyAudio
Old 6th November 2012, 02:20 PM   #1001
merlin el mago's Avatar
Connected again for warmp up, I will tell you voltage Vin at the reg with Vout 290V
Old 6th November 2012, 02:21 PM   #1002
Originally Posted by Salas View Post
What voltage is C1?
In the SSHV2 0.33uF 400V.
Old 6th November 2012, 02:24 PM   #1003
Only to be clear, actual measurements done with:
-EI core tx 240V
-Cap 1uF 450V at the input reg
-PSU without resitors only rectifiers UF4007 + 2 caps 220uF 450V
Old 6th November 2012, 02:28 PM   #1004
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Does 840 have a pad? Is it live to the sink maybe?
Old 6th November 2012, 02:32 PM   #1005
Yes have a pad, it's transparent so you can't see, I measued for continuity between heatsink & 840, meter measures no continuity.
Old 6th November 2012, 02:40 PM   #1006
Salas's Avatar
Lets knock down some resistance on that 47R to see if it draws more. Having another one to solder on top of it?
Old 6th November 2012, 02:41 PM   #1007
Do you want to parallel other resistor with 47R? wich value?
Old 6th November 2012, 02:45 PM   #1008
Salas's Avatar
The one 47R you substituted for the trimmer, lets make it smaller by paralleling another one on top of it.
Old 6th November 2012, 02:49 PM   #1009
For example other 47R in parallel?
Old 6th November 2012, 02:51 PM   #1010
Salas's Avatar
Yes
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
Copyright 1999-2017 diyAudio
