luxman k-15 - rec mute problem
Old 27th February 2009, 04:36 PM   #1
wmincy is offline wmincy  Malaysia
Default luxman k-15 - rec mute problem
Dear all,
I have an old second hand Luxman cassette deck model K-15.
Even if 20 more years had past, this machine still sounds incredibly good. It was well built with it's almost 12kg weight.
I have a problem with the rec mute function.
It doesn't work, and I tracked down where the problem could be.
In fact, looking on the pcb, I found a missing connection at the rec mute signal pin, seems the wire was cut and I can't figure out where must this signal be connected to.
If you got this cassette deck can you please help me out with this?
Kindly appreciate!!
thanks
Mincy
the fever of DIY HI-FI will NEVER be cured !!!!
Old 27th February 2009, 04:38 PM   #2
another picture.
luxman k-15 - rec mute problemHide this!Advertise here!
Luxman A-522 Rega Clone speed problem kffern Analogue Source 3 2nd October 2007 01:01 PM
Luxman Amp Problem memomat Solid State 2 6th January 2007 05:48 PM
Mute resistor value Lico Chip Amps 3 4th February 2005 05:40 PM
Mac 1900 pre amp starting mute problem wleediy Solid State 0 8th October 2004 09:04 PM
please help - no mute but did mute mod - tda1541 loomis Digital Source 1 14th November 2002 11:54 AM
Copyright ©1999-2017 diyAudio
