Calling all Rek-O-Kut Experts ! ! ! - Page 2 - diyAudio
Old 13th March 2014, 11:16 AM   #11
Still no clue on this? I may have to buy a junk one off some auction site and take it apart to find out how it works. Really do not want to change tonearms....
NOSValves Scott 299D, Rek-O-Kut N-33-H, Klipsch Forte' I, ALK Crossovers, Ti Diaphrams, Music Streamer II+
Old 14th March 2014, 12:35 AM   #12
dtut is offline dtut  United States
I'm going to retrieve my re-wired Micropoise from storage in the next couple of days. As I told Luckytiger over on AK, I don't remember the job being particularly hard, just a bit of a PITA. If I come up with some useful information, I'll post it here and at AK.
Doug Tuthill
Old 10th April 2014, 03:20 AM   #13
Things weren't quite the way I remembered them, but I did re-wire a Micropoise and posted the adventure here.
Rek-O-Kut Micropoise re-wire - AudioKarma.org Home Audio Stereo Discussion Forums
I hope this is helpful and if I can answer any questions, please let me know.
Doug Tuthill
Old 10th April 2014, 11:29 PM   #14
kevinkr's Avatar
Non audiokarma members cannot see the pictures - I know I tried. In general we are not that crazy about people linking to threads on other forums for this reason amongst others. Please consider posting the information here for our members..
Thanks...
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 10th April 2014, 11:37 PM   #15
Thanks Kevin,
I didn't realize there was a problem. I'll get something posted here soon.
Doug Tuthill
Old 10th April 2014, 11:54 PM   #16
kevinkr's Avatar
Excellent..
I'm curious to see your solution as well..
Old 14th April 2014, 08:32 PM   #17
Back a couple of weeks ago, maybe longer, I said I'd post about a Micropoise re-wire I did. Several guys, here and on another forum asked about that. I thought I had already done one and would just have to take pictures and explain the process, but I mis-remembered, another old guy moment, and had to figure things out from scratch.
Disassembly involved removing the original interconnect wires, which were very stiff and I didn't want to use them. A screwdriver blade popped the black plastic fitting at the bottom of the pivot post and the internal wires were cut. The jam nut was removed and the entire arm was removed from the TT.
If you look closely at the photo of the bottom of the pivot, you can see a collar with a set screw and, above it, a very fine wire keeper clip. DON'T REMOVE that collar unless you enjoy chasing a large number of very small bearings. The keeper does have to come off if you want to remove the pivot from the cone shaped support, which makes things easier.
I removed the arm from the pivot. Take the head shell and CW off and back off the screws from the vertical bearings until the arm is free. There is a small spring and a plastic fitting under the VTF adjuster which have to be removed but, if you're careful, they come out easily. Pull the arm out from behind the pivot. The wires will come out of the pivot with the arm.
I found that working over a pie plate which could catch small parts was a very good idea.
There is a rubber plug at the headshell end. There are four tiny pins that barely stand above the plug, but they can be removed with needle nose pliers or a blade like Xacto or a jeweler's screw driver. It takes time and it's a PITA, but it can be done. Expose the wires behind the pins, cut them leaving enough wire to grab for unsoldering, and then pull the wires out of the arm. If you're lucky and the pins are undamaged, use them for the new wires.
I wrecked a couple of the pins so I had to make new ones. I had some 1/16" brass tubing I bought in an Ace small parts section. I cut four pieces the same length as the original pins. I cut them a bit long, filed both ends flat, and beveled one end. Use a small, sharp point to open the hole in both ends.
I used mouse wire for the new wires. I cut and twisted two pairs, one CW and one CCW, in a hand drill. I used other mouse wire for the drag wire. I threaded two wires at a time back through the rubber plug. Pay close attention to polarity and wire color while you're doing this. I got it wrong at least once and that's really irritating. Fish the wire ends out from the hole at the pivot position. Strip and tin the drag wires and the new wire pair. Solder a butt joint between the drag wires and the new wire pair then carefully pull the new wires into the arm and out through the rubber plug. Repeat for the second new wire pair. Check to make sure polarity and color are correct. Remove the drag wire. Check and double-check polarity - it's very easy to get confused. Have the headshell nearby for reference.
Slip whichever kind pin you're using over the exposed tinned wire and solder. The insulation should bump the bottom of the pin. If you're using the brass pins, put the beveled end closest to the insulation. The bevel helps with the initial seating when installing the pins. Pull the wires back until the pins are touching the holes in the rubber plug. Use needle nose pliers to set the pins in the holes. The original pins should slide in easily. The brass pins are a tight fit. Move slowly making sure the wires don't crimp and set the pins until the heads are barely above the plug surface. Use a headshell to check pin height. They should be just high enough that the headshell mounts all the way back into the arm.
If you use resin for soldering, be sure to remove it before pulling wires or inserting pins. It's sticky and can bind parts just when you don't want that to happen.
With the headshell on, check continuity. If you're good, pull the wires at the pivot hole back into the pivot and re-assemble the arm. I found I had to insert the arm from the back of the pivot by putting the headshell collar end through first, then pushing the arm and pulling the wires at the same time until everything seated.
The process for the earlier S-120/160 arms is the same, but easier. Two of the photos are of an S-120.
I realize I probably should have taken more photos and I've probably not explained everything as well as I might. If there are questions or photos I can take, let me know.
I hope this helps.
Doug Tuthill
calling Wadia's experts inertial Digital Line Level 6 20th December 2011 08:42 AM
Calling all Soundstream experts chemhaz Car Audio 4 29th April 2008 02:01 AM
Calling all ATC mid experts! TwangBar Multi-Way 6 21st April 2007 02:13 AM
Calling all AD1853 experts tiroth Digital Source 6 7th August 2003 12:19 PM
Copyright 1999-2017 diyAudio
