Old 7th February 2009, 01:32 PM   #1
scott wurcer's Avatar
Default Preamp in the headshell?
I was toying with the idea of playing with preamplification in the headshell. Does anyone have a feel for how much mass I could add before things are unmanagable? I have a Grado in an MMT arm at exactly 10Hz resonance now. The setup is in storage so I can't fiddle with it now (I also forgot the brand of the headshell but it is some kind of premium carbon fiber thing).
2012, our time is running out.
Old 7th February 2009, 01:57 PM   #2
With the right SMT parts it seems like you could do it at under a couple grams. On the down side, you'll have extra wires for power, and the caps I'd want to use for even half the RIAA eq wouldn't be itty bitty SMT ceramics, but larger films. Fortunately there are lots more SMT part options now than even a couple years ago. IMO, it's a good idea to investigate, along with putting the pre in the table itself. I know that's been done commercially.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 7th February 2009, 03:57 PM   #3
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
As Conrad says, it should be possible with SMD parts to keep the circuit under a couple of grams. I do think you should leave any RIAA equliziasion out of this circuit, and just make it as a clean buffer with gain of e.g. 20-40dB. Resistors in the receiving end could bring signal down to what normal RIAA circuits accepts.
My thoughts are going more to shielded cables and a piece of mu copper around the shell
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 8th February 2009, 03:21 AM   #4
SMT caps are problematic, but you can get 1206 NPO now up to .1u and I think I remember higher. I was thinking of a phantom power arrangement similar to the Schoeps transformerless mic circuit. There are several external sound devices with P48 and balanced inputs. You could also try RIAA in software or a hybrid approach.
Old 8th February 2009, 05:13 AM   #5
SY's Avatar
We did this back in the '70s, with some high gm FETs (CM860, if memory serves), drilled some holes in the headshell to mount the FETs, then remote powered it. That didn't add too much mass. Worked very well.
“There are no greater liars in the world than quacks, except for their patients.” - Benjamin Franklin
Old 8th February 2009, 07:42 AM   #6
analog_sa's Avatar
Default Re: Preamp in the headshell?
The dream analogue source for the "hear no difference" brigade.
Hey, i have other bright ideas for you. How about making a speaker cable with "network boxes" which in fact hide power amps? Wouldn't that be something to play your headshell riaa through?
Old 8th February 2009, 08:42 AM   #7
h_a is offline h_a  Europe
h_a's Avatar
Certainly one could do that - at least to fit a single gain stage - even if your setup seems not to be perfect for this task (low compliance MC like SPU, Denon DL103 and the likes that benefit from high mass arms).
As I'm currently working on my phono, I would be more sceptical regarding shielding. Even a simple alu-box is probably already too heavy and without shielding it's likely to pickup lots of noise so there's no net benefit.
But being the person you are, you already thought about that
Have fun, Hannes
Old 8th February 2009, 09:04 AM   #8
Jan Dupont's Avatar
my-copper - Not alu
Old 8th February 2009, 09:17 AM   #9
tvi is offline tvi  Australia
tvi's Avatar
Or
Ballmann headshell mounted digitizer
This one digitizes at 768/24 at the headshell and sends the digital signal to a receiver at the armbase. Requires arm re-wiring
James
The border between the Real and the unreal is not fixed, but just marks the last place where rival gangs of shamans fought each other to a standstill. Robert Anton Wilson
Old 8th February 2009, 09:39 AM   #10
Jan Dupont's Avatar
Nice
Sadly using an AD makes the sound compressed like on CDs......
WTB headshell, Yamaha PX-3/PX-2 pfcs49 Swap Meet 0 24th January 2009 03:37 PM
Grace G-707 headshell Gram Analogue Source 14 27th July 2008 08:16 AM
Headshell bits gkimeng Parts 0 14th December 2007 08:08 PM
attaching a headshell spooky1234 Analogue Source 4 23rd March 2005 03:07 PM
Loose Headshell ross1976 Analogue Source 2 7th January 2005 05:52 AM
Page generated in 0.11351 seconds (78.92% PHP - 21.08% MySQL) with 10 queries
