Old 7th February 2009, 05:22 AM   #1
Default My TT is finaly ready
Inspired by this great forum I finally finished my TT.
Many thanks to Panicos who supplied my with the power supply for the Maxon motor.
Its just amazing how much better it sounds then anything I've heard before in my system.
Old 7th February 2009, 12:28 PM   #2
Panicos K's Avatar
Looks great Izhak
Old 7th February 2009, 01:06 PM   #3
SY's Avatar
That is a gorgeous piece of work. What sort of wood is the arm?
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 8th February 2009, 11:17 AM   #4
Stuey is offline Stuey  Australia
Very well made!
Are they wire-rope shackles at the pivot end of the arm? I don't know the correct name for these things...they consist of a U-bolt and a cast piece, used to clamp wire rope.
Stu
Old 9th February 2009, 02:57 AM   #5
jazzy939's Avatar
My hat to you, Izhak!
Mind sharing with us some details of the work?
Thanks. Have a nice day.
Old 9th February 2009, 12:49 PM   #6
Thank you all for the complements.
The arm is made of Bamboo and yes, both pivot and weight and attached to arm by wire clamps.
Both platter and splint are filled with lead shots.
Bearing is made of a ¾”x 5.0” very high tolerance hardened to 60 RHc and polished pin and highest tolerance available Bronze bushings total cost about $15.
Old 10th February 2009, 04:50 PM   #7
Good job Izik!
I hope you have a spiral groove on your bearing sleeve, otherwise lubrication may be a problem for the inverted bearing, especially for the ball.
Enjoy!
Michael
Old 11th February 2009, 02:00 PM   #8
Shalom Micheal.
The sleeves are "off the shelf" oil impregnated items. I didn't find any with spiral.
I just put few drops of oil before each play.( i drilled a small hole off-center in the Delerin plate )
If you ever stop by Haifa you are most welcome to visit and listen
Cheers
IK
Old 13th February 2009, 06:55 AM   #9
dario54 is offline dario54  Israel
A truly nice job!!
Can you post more pics/details about the tonearm??
Thanks!!!
Dario
Old 16th February 2009, 03:56 PM   #10
Thanks Dario,
Its pretty strait forward unipivot
The cup is 90deg. machined in a rope clamp.
The pivot is 60 deg with a small radius at the end.
Tonearm wire is taken off the back of a hard drive reading arm….
The Bamboo has a very thin layer of a very hard varnish (the type used to pain guitars) to make it stiffer.
Finaly - Custom Enclosures komigenie Vendor's Bazaar 6 14th March 2008 09:01 PM
I have finaly done it! They are ordered! inrank Full Range 9 15th October 2006 01:20 PM
Jfet/bipolar PCB and Schematic (finaly) sonnya Solid State 35 31st October 2003 03:39 PM
WEll there alive Finaly Pics jleaman Solid State 12 4th October 2002 04:44 AM
Page generated in 0.10009 seconds (76.93% PHP - 23.07% MySQL) with 11 queries
