Yet Another JFET Phono Preamp - Page 2 - diyAudio
Old 1st February 2009, 11:55 PM   #11
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
How much is your total gain at 1kHz? Bias current of Q5?
Old 2nd February 2009, 12:01 AM   #12
wrenchone's Avatar
I'm aiming for about 40dB at 1kHz, which matches up pretty well with the usual MM source. Bias current for Q5 is about 2ma.
Old 2nd February 2009, 12:07 AM   #13
Salas's Avatar
Yes 40dB is OK, no good to push the peak to peak on jfets for excess gain that is going to be thrown away on a volume pot. Why 16K Rload? Low inductance cart? A Grado?
Old 2nd February 2009, 12:10 AM   #14
wrenchone's Avatar
A Grado it is. I'm using a Grado Gold.
Old 2nd February 2009, 12:17 AM   #15
Salas's Avatar
A well balanced cart. On a good TT and arm is no slouch. What TT and arm? I also liked that little amp of yours with the shunt under the cathode instead of self bias or LEDs. I guess with efficient speakers, this phono combined with that amp is gonna sound very immediate and alive. Can it be driven directly from your phono with just a pot? Sensitive enough? You have the phono buffered already. Wishing you a great actual test with very little or no changes.
Old 2nd February 2009, 03:10 AM   #16
wrenchone's Avatar
I'm using a Kenwood KD2055, which is ok, but nothing to get excited about. I have a KD500 with no arm, and some SME3009-R arms. I wanted to put one together using an aftermarket bronze bearing to replace the stock nylon bearing and a carbon fiber head shell.
Attached are some simulation results for my preamp second stage - much lower distortion than a simple common source stage for the same output level.
Old 2nd February 2009, 03:14 AM   #17
Salas's Avatar
Interestingly the 2nd is more than the 3rd but the 5th is more than the sixth, 7th more than 8th. Very low in total off course. Is it changing pattern along the way? Can that shunt output bias amp be driven without a preamp, with the 40dB of the phono?
Old 2nd February 2009, 03:26 AM   #18
wrenchone's Avatar
I would only use the simulation results for indication purposes. The only thing I would conclude at this point is that the higher order products are likely to be low amplitude.
I could drive my little amp directly from the preamp, but I have no speakers efficient enough at this time to make the exercise worthwhile.
Old 2nd February 2009, 03:38 AM   #19
Salas's Avatar
I would make a Hemp FR8 Mass loaded TL. Very easy, would add an affordable Tangband Ribbon above 10kHz for sparkle. 94dB after baffle step correction, easy 8 ohm load, no imp dips. Can be done in a weekend if veneering isn't required. Goes deep, great focus point source all over psycho acoustically critical bands. Great TT for restoration you got by the way. Proper speakers, your 500 and the rewired SME will really highlight your excellent electronics.
Old 2nd February 2009, 09:28 AM   #20
Onvinyl's Avatar
Hi Wrenchone,
nice to see the journey proceeding!
What is your reasoning for chosing a current mirror as a ccs for the voltage reference zener? (as opposed to a fet or led/transitor based solution, for instance)
What is the bandwith and the noise performance of the regulator?
Thanks,
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 10:51 PM
How to house a JFET phono pre jackinnj Solid State 10 10th July 2008 01:59 PM
D.I.Y. "Duplex" 2sk369 jfet mm phono preamp doggy Analogue Source 6 26th September 2006 09:23 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 03:11 PM
Copyright ©1999-2017 diyAudio
