| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Please do you know a website where I can see some graphs about LP " lathe etcher" ? I am interested in performance about frequency response and channel separation Vs frequency. Perdone my poor english , I'm searching to learn about LP production phases/ process. Thanks for the help Cheers, Paolo |
#2 |
Excuse me,
I 'm referring obyouvsly to the stylus etcher of the lathe machine. Cheers, Paolo |
#3 |
Hi, I think the answer depends on the lathe - like asking "what is the response of a cartridge"
You should be able to get some expert advice here: http://lathetrolls.phpbbweb.com/ It's a forum dedicated to record cutting.
Analogue stuff at www.audiomods.co.uk |
#4 |
Yes Jeff, you are right!
Perdone me, I was curious to see if a "very-good" stylus heatcher has the same issues as like a "good" MC cartridge .........to say a channel separation of about 30dB or even worse! Very thanks for the link, probabily it is the best place to ask for ! Cheers, Paolo |
#5 |
bring back dynamic range |
#6 |
Fantastic Werner!!
It is exatcly what I need. Just one question befor read all the link : Is this the stylus for the production of the "master LP"first piece, am I right? Then , from this master, they derivate all the copies for sell, no? Perdone my basics question , I am newbie on analogue! Thanks very much, Paolo |
#7 |
Yes.
But this is for a 'modern' Ortofon head developed for 4-channel recordings. These were/are not often used for commercial LPs. I assume that the performance of the more often used Neumann SX-66 and SX-74 cutter heads is a bit worse.
#8 |
Thanks! you are very kind
I have a strange question: Suppose we make the first Master piece with that Ortofon machine, we have about 30dB of separation ( approx, just for understand). When we take the master and derivate all the copies can we assume approx we are loosing others 6 dB thus in total our final product is 30-6 = 24dB approximatively? Cheers, Paolo |
#9 |
I don't think the further process of making mothers, stampers, and finally records does much harm to channel separation.
I have often measured separation in excess of 30dB using commercial test records, so this is definitely possible. On the other hand, expect treble response to suffer severely from the production.
#10 |
Excuse me,I don't understand.
If I make a second "read" from master to write the copies, I am making the process two times so you have 30db separation on the "residual" presents in the master, or not ? Am I totally wrong in my reasoning? Cheers, Paolo |
| 1960's Record Cutting Lathe Bearing | null object | Analogue Source | 1 | 22nd March 2011 09:16 AM |
| Baluster turning/lathe in Washington DC Area? | dgoodier | Everything Else | 0 | 8th August 2009 12:49 AM |
| Tooling (lathe / mill) recommendations ? | ckniker | Analog Line Level | 1 | 18th August 2007 06:20 AM |
| CD Lathe | soongsc | Everything Else | 10 | 28th October 2005 06:00 PM |
| MDF on a lathe? | masterp2 | Multi-Way | 20 | 29th January 2004 12:30 PM |
| Page generated in 0.10212 seconds (78.04% PHP - 21.96% MySQL) with 10 queries |
