Old 29th December 2008, 07:34 AM   #1
honinbou's Avatar
Default Japanese Papst on steroids (a Sony motor)
Has anyone ever seen one of these in their reel to reel decks?
Turns out that it's a Japanese version of the Papst “flywheel” motor.
Would this make a good turntable motor? Well the shell is already balanced.
Old 29th December 2008, 10:32 PM   #2
I got one that run with 720RPM with 50V AC but the torque is a bit low to be used as a turntable motor.
Old 30th December 2008, 05:31 AM   #3
honinbou's Avatar
thanks.
I guess it will put this motor back into the reel to reel.
Old 30th December 2008, 08:22 AM   #4
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Originally posted by Mikewong
... but the torque is a bit low to be used as a turntable motor.
So long as it can keep the platter going round you don't need really much torque. Nottingham Analogue use such weedy motors that you have to start the platter moving by hand - the motor can't start it. That motor looks good to me.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 30th December 2008, 08:46 AM   #5
qwad is offline qwad  Australia
agreed, l had a no-name tt one time that once you put a dustbug on the lp had to be hand assisted to come up to speed, but once there kept going all day without missing a beat
cheers T.C.
we all have problems only some people have more than most....
long live the Magyar (Hungarians) in the world!
Old 30th December 2008, 02:45 PM   #6
Nanook is offline Nanook  Canada
Nanook's Avatar
Default honinbou,use the motor!
if its as good as it appears, use it! nothing wrong with low voltage.
As EC8010 points out, not much voltage is required to keep a motor spinning (and platter) once it is up to speed.
In fact to get a correct speed, you may have to alter the voltage (if DC type) or change the frequency if AC type and the voltage.
Air pax motors used in Linn LP12 turntables apparently run great when fed 72VAC or so...
stew
Edit: Spoonerisms edited out by moderator!
stew -"A sane man in an insane world appears insane."
Old 31st December 2008, 09:07 AM   #7
And here is the attached photo.
Old 31st December 2008, 02:04 PM   #8
Nanook's Avatar
Default Mikewong...
if I recall, as motor speed drops, torque increases in a linear fashion (almost). Feed that motor with a different frequency, and drop the voltage. Speed will be reduced and torque will increase, perhaps making it suitable for a turntable. Or do some math, calculate the required platter speed, then make an intermediate pulley (2 stepped) to be driven by the motor and to drive the platter.
stew
Happy New Year to all, where ever you are
Old 4th January 2009, 07:33 AM   #9
honinbou's Avatar
Thank you all. I guess I'll keep the flywheel motor for a future turntable project.
Old 5th January 2009, 11:14 PM   #10
Great find!
For interest, here's a link to photos of my Dyna Empire 208/Papst set on Flickr.
http://www.flickr.com/photos/worldwi...7603524842069/
Is yours a 3-phase EC motor like the Papst??? I'm still looking for a digital-analogue controller for mine.
Sony PS-X70 dead motor pole? Don Nebel Analogue Source 5 5th November 2007 09:12 AM
Papst Induction Motor. Paul Dimaline Analogue Source 3 20th March 2006 09:24 PM
Sony. Motor Probem. jleaman Digital Source 18 6th June 2004 09:16 AM
Sony pickup KSS-210A turntable motor? capslock Digital Source 6 26th March 2003 11:28 AM
Page generated in 0.10313 seconds (77.85% PHP - 22.15% MySQL) with 11 queries
