DIY Air bearing tangent tone arm
Old 2nd March 2012, 02:41 PM   #141
AVWERK is offline AVWERK  United States
AVWERK's Avatar
What is the length from pivot to stylus? If your arm is like a Versadynamics style and very short, you need a vacuum platter seriously or bass response will be a mess and consume most of your amplifiers power
For starters, is your cartridge mounting platform parallel to the record surface? Most cartridges but not all!! Get VTA in the proper range when in this arangement.
If the back of your cart. Is higher that the front side, then this tips the VTA balance to the higher frequencys and the opposite etc.
Have you made any other changes to your system that might have an impact?
I also have an ET1 and ET2 arms with subs and bass is deep and tight, but requires proper handling of setup compared to pivoted arms
If you have any 60 cycle hum from your phono stage this will also rob you of bass potential.
David
Old 2nd March 2012, 09:03 PM   #142
fmelindy is offline fmelindy  Canada
Yes the VTA is significantly off, with the cartridge tilted forward (slopes up from front to back). I'll try dealing with that first. So the consensus is that this is probably the issue? Or are there other ideas?
Old 2nd March 2012, 09:24 PM   #143
clivetjm is offline clivetjm  United Kingdom
I think you know with 90%+ confidence what the issue is.
Old 3rd March 2012, 01:59 AM   #144
Yes, that seems to have made a large difference
Old 3rd March 2012, 03:22 AM   #145
By the way, how critical is it that the holes be 0.3 mm? I just noticed that mine are larger than that and i do get a fair amount of hiss... is that why, you think?
Old 4th March 2012, 10:05 PM   #146
Well, I'm learning as I go for sure! I just remedied this as well and made sure that all holes are exactly 0.3 mm and that they all have the same level of air flow and that made a HUGE difference. It made a huge difference not only to the sound of the music but to the sound of the arm - it's virtually silent now with no hiss and far less air flow needed. And the bass is back!
To any newbies or people trying this for the first time... don't cut any corners, do it right the first time! At least then you'll be able to content yourself that the flaws in the sound are not the direct results of flaws in your construction. Make sure:
1 - you have no air leaks anywhere
2 - your holes are drilled properly and are of the proper size (double check your air flow!)
3 - your carrier is level and stable
4 - you use a smoothing tank
5 - your arm wand allows you to parallel the cartridge to the record surface precisely
6 - your wiring is very limp and light (and using the gantry to keep the wires elevated is a good idea)
I'm by no means an expert mind you, these are just the issues I had to confront when I was building the arm!
Old 15th May 2012, 02:11 AM   #147
toptip is offline toptip  United States
Default Tangential arms
All linear tracking arms I have come across either use a mechanical pull or a compressor / air tube combo or, very rarely, some magic glass which supposedly has no friction (there is at least one, Swedish I think). These all have drawbacks, mechanical ones can produce a "thump" noise, air bearings get dirty, compressors are noisy, etc.
What I have never seen is a magnetic levitation arm, meaning a piece of ferrous metal floating in a magnetic well where it is repelled from the bottom, the back and the front with some electromagnetic system. Why would this not work, they build trains that levitate?
Or may be it already exists?
Old 16th May 2012, 08:42 PM   #148
Sourdingue is offline Sourdingue  France
Sourdingue's Avatar
Good evening, I took the post in progress and will share my experience perssonelle. I realized a pneumatic tangential tonearm, the largest Difficulty is to reduce the noise airflow, for my part of the solution was to make drilling tube to 0.2 mm at a pressure of 0.250 bar (flow is adjustable by a limiter) ....
I found the manufacturer of the tire fitted to the socket "kuzma" I considered this option early, then I left ... because the price is high and above the pressure needed for proper operation is much stronger which leads to greater problems of residual noise reduction ..
(sorry for my bad english ...)
Old 18th May 2012, 06:17 PM   #149
drumdoctor is online now drumdoctor  United States
Default hole spacing
What is the spacing used between each hole? Do you use just one set of holes along the top of the tube?
Old 19th May 2012, 09:41 AM   #150
Sourdingue's Avatar
hello,the spacing between holes is 6mm and only on the top which is quite sufficient..
DIY Air bearing tangent tone armHide this!Advertise here!
Looking for Audax bextrene driver for Tangent RS6 dcanuck Multi-Way 4 2nd November 2011 11:30 PM
Tangent's ground channel w/o buffer morfic Solid State 17 2nd August 2009 04:20 AM
Tangent RS4 Speakers - free happyju Multi-Way 0 14th April 2008 03:50 AM
Tangent Monitor 6 upgrade SimontY Multi-Way 8 6th February 2008 10:24 PM
Help with Air Tangent problem arnoldc Analogue Source 3 21st June 2004 05:28 AM
