Why rega plinths have to be low mass?
Old 13th December 2008, 02:22 AM   #1
reyrios is offline reyrios  Mexico
Question Why rega plinths have to be low mass?
I have taken my rega planar as far as it can go with all the mods in the market, platter, counter weight, feet, rewire, etc, etc, it is been a fun ride, but I have always dream of a nice hard wood plinth, it does note have to be 4 inches wide, but 1 and a half would be nice, the only thing that has stop me is all the comments about the original plinth being a essential part of the rega design, if you ask me, it is all about keeping such design under budget. Anyway, thanks in advance for any advice
Old 13th December 2008, 05:00 AM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The layest lightweight plinths are certainly not cheap or budget consious... they really do believe in low mass/low energy storage.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th December 2008, 07:12 PM   #3
Panicos K is offline Panicos K  Europe
Panicos K's Avatar
Further,the plinth of planar3 is not only light,but it is not even solid.It seems to be a sceletal chassis covered by the thin black finish on top ,bottom and sides
Old 30th December 2008, 11:11 AM   #4
ALBQ is offline ALBQ  United States
Default Which Begs the Question...
All of this of course begs the question; has anyone peeled the laminate off of a P2 or P3 to see what was underneath?
We all know Rega uses a laminate covered particle board but, what did they actually do to it?
Pictures anyone? Documentation?
Cheers -ALBQ
PS - No Rega slam intended - P5 w/Dynavector 17D3 owner
Old 30th December 2008, 11:16 AM   #5
Panicos K's Avatar
I actually learned about this when I was asked to re-wire the tonearm on a Planar3,and put a RCA socket output plate underneath.When I tried to screw the plate,one of the screws went through the laminate and there was nothing in there to screw on.Sorry,no pictures
Old 30th December 2008, 02:36 PM   #6
Nanook is offline Nanook  Canada
Nanook's Avatar
Default low mass=low energy storeage
dude! have a look (in my best Jeff Spicoli So' Cal surf-talk voice) at this
That is something I've been thinking about, an uber stiff, uber light plinth ( at least for the bearing and platter). There are some benefits to having a massive "base" plinth for a turntable, If it is a multi plinth design.
Ken Lyons used to hang around here a bit, and audioasylum as well. He makes some great light weigh shelves for various equipment stands, at Greater Ranges . I've got an 85-90% (so sez Ken or said) DIY one. I shall not divulge any info as it is proprietary, and I don't own the patent or copyrights, but Ken stated in my first try I was at least 85-90% of the current Neuance shelves. He did share a few trade secrets with me, but his first question was "did you cut a Neuance apart?"
Sorry I can't afford to cut apart his great shelves, they are a little expensive to buy one and hack it apart.
The same thing can be said about loudspeaker enclosures. Everything else being equal, a lighter enclosure stores less energy and therefore when it does release spurious energy (and all enclosures do), the amplitude of the energy release is much smaller in magnitude.
stew
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
Old 1st January 2009, 04:36 PM   #7
jlsem is offline jlsem  United States
jlsem's Avatar
These chairs are cut from alternating layers of corrugated cardboard. They are stronger than you'd think. I would consider this method for a lightweight plinth or speaker enclosure.
http://www.vitra.com/en-un/home/prod...le-side-chair/
John
"Those who abjure violence can do so only because others are committing violence on their behalf." - George Orwell
Old 16th January 2009, 06:04 PM   #8
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Why rega plinths have to be low mass?
They use particle board, they can market it as low energy storage all they like, it's not true, it doesn't have a particularly fast transmission speed for vibrations and it's not particularly stiff.
If they made them out of Nomex/carbon laminate then perhaps there might be some truth to their marketing puff, but frankly it's just that, smoke and mirrors.
P5 owner who replaced plinth with wood block and mounted motor and arm onto carbon fibre plates.
Paradise Pre-reg PSU PCBs
Old 13th March 2009, 01:37 PM   #9
cameronbs is offline cameronbs  Canada
Default Looking for jlsem - Dallas Texas
Hello to all;
I'm looking for jlsem - and cannot contact him directly because I am being moderated as anew member. He has done work for Albert Porter - and Albert and I are currently testing similar gear.
As a woodworker, John is the man I need to speak to regarding some technical advice for the SP 10 MK II and MK III plinths he has made.
I propose to reconfigure his plinth to accomodate Garrard 301 and 401 tables. I would appreciate if someone could ask john to contact me at "bobcame2@telus.net" I don't wish to contravene the protocol of this site - but I am need of specific information - and thought I may speed the process this way. Thanks.
Bob Cameron
Why rega plinths have to be low mass?Hide this!Advertise here!
I'm getting custom acrylic plinths made for the Planar 3. Who wants one? mattjk Analogue Source 4 2nd March 2011 08:02 PM
Mass Confusion weinstro Multi-Way 6 20th November 2008 01:58 AM
More plinths jlsem Analogue Source 6 17th January 2008 03:32 PM
Has anyone modified their SL-1200Mk2 plinths? virak Analogue Source 3 20th January 2007 12:41 AM
Adding mass to PR.... hofffam Subwoofers 1 7th January 2005 12:01 AM
