Old 19th April 2012, 08:25 AM   #921
Hello Frank
Do you think these type of suspension can work well with longer tonearm like 15" or 16"? One will be 12" that sure.
Also these would be the material for arm wind guys you advised to me? You wrote I think you like it a lot these or similar material...
I do not want to buy in case these not the same, please remember I have ultra light weight titanium, 2 size carbon fibre and aluminium arrow shaft( similar to Naim wand).. All light weight and they do look promising.
Garolite XX Bakelite Tube, .500" OD x .063" Wall x 12" | eBay
Would you please let me know.
Thank you
Greetings Gabor
Old 19th April 2012, 09:27 AM   #922
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Originally Posted by woodturner-fran View Post
I did another few bits with the arm. The most significant thing was something I remembered frank saying a while back. I decoupled the counterweight. So it now sits on 3 o-rings very similar to how the original rega counterweight was done. The difference in this is not small.
I also made a rest so I can lock the arm when not in use. Makes it a lot safer when kids are about. Anyway I think it's time for a few pics!
I shot a short video that's up on YouTube:
VIDEO0091.3gp - YouTube
Fran
Sweet !!!! Which test LP are you using ...?
Old 19th April 2012, 05:23 PM   #923
The one in the video is a cheap compilation "the rough guide to new orleans". It's actually very good sonically and musically!
Fran
Old 19th April 2012, 06:47 PM   #924
a.wayne's Avatar
No i mean actually test LP, what are you guys using , The Hi-fi news edition ? Others?
Old 19th April 2012, 07:09 PM   #925
Oh sorry!! Yes the HFNRR record - and I use a feickert alignment gauge to do the alignment.
Fran
Old 20th April 2012, 11:23 AM   #926
Hi Gabor,
Without having tested the tubing that's offered under the ebay link, I can't say whether its's suitable or not. For armwands, I only use such a material as the outer layer of a three layer sandwich.
Generally speaking, most phenolic tubes of suitable diameter/wall thickness are not stiff enough to be used by themselves, not to mention for 16" arms.
have a great wekend,
Frank
Hi Fran,
Why did you make the headshell/armwand interface so fragile and the mounting plate so massive?
Old 20th April 2012, 01:16 PM   #927
The mounting plate: basically its what I had to hand. The headshell is pretty strong - its made from a single piece of aluminium. It "feels" strong if you know what I mean.....
Fran
Old 20th April 2012, 09:09 PM   #928
Algar_emi's Avatar
My Schroeder arm is almost completed. It missing only the wood wand tube. Here the pictures. It has a micrometric VTA adjuster kind like the one on the Graham tonearm. Counterweight with fine adjuster brass screw, plastic (Rulon material) sleeve insert between arm tube and counterweight for smoother adjustment and vibration control. I'll use a kevlar thread for the pivot point. The mounting hole is the same as a REGA, lifter (JL-45) from Jelco. It will need a custom slide section. The standard one is not long enough.
Old 20th April 2012, 09:14 PM   #929
Algar_emi's Avatar
woodturner-fran you have mail
Old 22nd April 2012, 02:20 AM   #930
dtut is offline dtut  United States
Beautiful work all of you Schroeder builders. Major props all the way around.
Doug Tuthill
My DIY Turntables and Schroeder based tonearm konstantin Analogue Source 24 26th March 2010 05:35 AM
Linear tracking tonearm vs. Pivoting tonearm Don Nebel Analogue Source 1 4th November 2007 10:49 PM
DIY Schroeder "Clone" Capt Zach Analogue Source 18 3rd March 2006 06:57 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
