Old 4th November 2009, 07:03 PM   #281
Very interesting graphic representation of magnetic flux / fields interaction:
K&J Magnetics - Magnetic Fields
Old 4th November 2009, 09:04 PM   #282
An interesting PDF on "potted" magnets...
http://www.goudsmit-magnetics.nl/fil...potmagneet.pdf
and a pull calculator....
http://www.kjmagnetics.com/calculator.asp
Old 4th November 2009, 11:27 PM   #283
MRupp is offline MRupp  Germany
MRupp's Avatar
perhaps if you twist pairs + and - for each channel, then the external ground/shield would not be neeeded, as twisted pairs have a shielding effect.
FWIW: If you are interested in reduced RF interference you could off course use a star-quad arrangement of the tonearm wires, i.e. +-+- for each channel. Compared to a twised pair you will get another 20dB of noise rejection, off course at double the cable cost.
Nonetheless I am surprised that you do not see this arrangement even in high end tonearms where cost should not be an ojective, though van den Hul does recommend star-quad topology (and would be selling twice the length in cable along with it ).
Martin Rupp
Old 5th November 2009, 12:50 AM   #284
binspaul's Avatar
Send a message via Skype™ to binspaul
Hello Martin,
The start-quad concept seems interesting....
Best regards,
Bins.
Old 5th November 2009, 02:57 AM   #285
I will be doing up a star quad interconnect from the juction box rca's to my phono stage.
What limits me from doing a star quad is that it will require a pair of star quads through the tonearm proper. That means it's twice the thickness and probably very difficult to thread through the tube. Also, where th wires exit is importatant because they will have more force upon the free rotation of the arm and could interfere with the anti-skate settings and if too stiff, also cause mistracking... true we're talking about 32ga. wires, but having a total of 8 exiting the arm gives me a bit of pause. If we were to go a finer gauge, then the workability becomes a factor also...probably impractical .
Jeff
Old 5th November 2009, 08:14 AM   #286
binspaul's Avatar
JD,
You are absolutely right. I too is having a 32 AWG wire. What about having a simple shield using a bare wire wrapped around the twisted pairs so that it will act as an antenna ?
Best regards,
Bins.
Old 5th November 2009, 09:57 AM   #287
K.A.B is offline K.A.B  Sweden
K.A.B's Avatar
I made my own braided tonearms cable with good results with Cardas 33 awg wire.
Then a couple years back I have seen cardas do the same and there are a shielded version too Dedicated Audio - Cardas 33AWG Braided (4) Conductor Tonearm Cable
Take Five Audio - Canada's Online Source For High-End Audio, Parts and Accessories - Cardas
Anders
Old 5th November 2009, 11:21 AM   #288
MRupp's Avatar
Several years ago I rewired my Thorens TP-90 tonearm (TD 2001 table) with a pair of star-quad cables made from Van den Huls MCS - 150 M (not as expensive then as it is now); the external diameter per single wire is 0.25 mm, so 0.5 mm per cable and it does not seem to be impeding the movement of the arm. Also, twisting the four wires together was much easier than I had first anticipated so it should be easy to do even with very thin wire.
Regarding the braided version that Anders is mentioning, I cannot comment other than to say that mine is not braided but twisted. I am not sure how much difference this makes but the idea of the twisted star-quad is that the ("electrical") centre of each pair of conductors (i.e. ++ / -- is exactly in the middle of the cable so that both are overlapping, same as in a coaxial cable, which then explains the reduction in noise pickup. The 20 dB figure is actually from an AES lecture by Bill Whitlock of Jensen transformers which I found on the WEB - and very interesting: AESUK_lecture_0705.mp3
Martin Rupp
Old 5th November 2009, 03:14 PM   #289
I don't know if I'd like to braid both channels (L+R) into one braid, or even twist all 4 together. I'd be afraid of potential cross-talk between the channels.
Jeff
Old 5th November 2009, 03:30 PM   #290
MRupp's Avatar
Jeff
Maybe my previous posts were not clear, but I was NOT suggesting to use 4 wires in total, i.e. to twist both channels together. This is unfortunately the usual approach which you will see in most tomearms.
My suggestion is exactly to use 2 times 4 wires, configured as a proper star quad, i.e. 4 wires per each channel, so that there is no crosstalk between them.
P.S. On a separate note, and after listening to the AES MP3 again, the 20dB as quoted above should read "up to 40dB", though I am not sure what this is relating to, i.e. 40 db better than twisted pair or untwisted conductor pair.
Martin Rupp
My DIY Turntables and Schroeder based tonearm konstantin Analogue Source 24 26th March 2010 06:35 AM
Linear tracking tonearm vs. Pivoting tonearm Don Nebel Analogue Source 1 4th November 2007 11:49 PM
DIY Schroeder "Clone" Capt Zach Analogue Source 18 3rd March 2006 07:57 PM
Page generated in 0.08890 seconds (69.95% PHP - 30.05% MySQL) with 11 queries
