Old 3rd November 2009, 10:35 AM   #271
zeonrider's Avatar
Originally Posted by krishu View Post
IMHO the ground wire should be connected to the arm tube as close as possible to the tonarm bearing, i. e. not at the headshell. But that might work as well.
Christian.
Tube made of wood!
Regards zeoN_Rider
Old 3rd November 2009, 01:08 PM   #272
binspaul's Avatar
Send a message via Skype™ to binspaul
Hi ,
The arm tube is not fully made up of wood. The rear end of the arm wand is of Aluminium. I think Christian is right. I too was thinking in the same line. But, will that affect the eddy currents generated in the aluminium tube ? In that case, the best place will be the head shell.
@Frank: What is your suggestion ?
Best regards,
Bins.
Old 3rd November 2009, 01:18 PM   #273
zeonrider's Avatar
Thumbs up Hi!
Originally Posted by binspaul View Post
In that case, the best place will be the head shell. What is your suggestion ?Bins.
Headshell
Old 3rd November 2009, 04:21 PM   #274
ah... but what if the arm tube is made of wood as the Schroeder is?
Christian.
Old 3rd November 2009, 05:53 PM   #275
Magura is offline Magura  Denmark
Magura's Avatar
Originally Posted by Jeffrey Davison View Post
Brass and Aluminum get a bit too friendly after a while, this thing called electrolicic reaction, don't ya know.
JD
So does copper and aluminum. You need to do something to prevent galvanic corrosion.
I am speaking from very bitter experience.
Nice project though.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 3rd November 2009, 06:39 PM   #276
I brush on a nice coating of "Anti-Seize" compond from a company called SAF-T-EZE,(STL Compund Corporation).which contains nickel and graphite in it's lubricant, around threads and movable mating surfaces.
The stuff is easily found in hardware stores and automotive supply shops.
Machine oil, imo, just doesn't offer enough protection in the long haul and has a habit of running off over time, The Anti-Sieze is tenacious and stays where put.
JD
Magura
Old 3rd November 2009, 07:05 PM   #277
krishu is offline krishu  Europe
krishu's Avatar
then you need to put some shielding into the wooden tube, e. g. a small carbon tube or metal foil which then is connected to ground. You could also use shielded tonearm cable in the tube, then no further shielding is necessary.
Visit my DIY page at www.krishu.de
Old 3rd November 2009, 09:21 PM   #278
perhaps if you twist pairs + and - for each channel, then the external ground/shield would not be neeeded, as twisted pairs have a shielding effect.
So there would be two twisted pairs from the cartridge clips, through the arm and out to the rca's ( or whatever interface. (I'm using a Lemo connector on a junction box with a pair of RCA's to the "outside" world. THe junction box is connected to the turntable ground. This works very well in a modified SME/Thorens TD160 I've been using for a while now... Only 4 wires through the arm to the RCA's and no hum.... and the armtube is NOT grounded.
JD
Old 3rd November 2009, 09:32 PM   #279
zeonrider's Avatar
JD
That what I, talking about.
4 wires twisted and one wire around 4 signal wires.
Regards zeoN_Rider
+ thin metal plate above head.
Old 4th November 2009, 04:03 AM   #280
binspaul's Avatar
Hello JD,
1. Nice suggestion. How many twists (twists per foot) do you use for the cable ?
@Frank: What is your suggestion ? This is getting more complex...
Best regards,
Bins.
My DIY Turntables and Schroeder based tonearm konstantin Analogue Source 24 26th March 2010 06:35 AM
Linear tracking tonearm vs. Pivoting tonearm Don Nebel Analogue Source 1 4th November 2007 11:49 PM
DIY Schroeder "Clone" Capt Zach Analogue Source 18 3rd March 2006 07:57 PM
Page generated in 0.10477 seconds (70.79% PHP - 29.21% MySQL) with 11 queries
