Old 2nd November 2009, 07:17 AM   #261
binspaul's Avatar
Send a message via Skype™ to binspaul
Hi JD,
Nice work, keep posting...
I am still having some issues with the anti-skating wheel. How is it mounted to the top plate ? Is it press fit ? Are you using some rubber/foam layer in between ?
Best regards,
Bins.
Old 2nd November 2009, 07:44 AM   #262
It's what they call in engineering terms a "sliding fit", the thumbwheels shaft diameter is a couple of thou smaller diameter than the hole.
Remember, it has to have free rotation to be adjustable. But the tolerences still have to be fairly tight, otherwise you can get a missalignment from the thumbwheel on top and the center of the magnet housing on the bottom plate, and that's asking for an arm that wont work correctly. Also I use just a dab of anti-sieze in the hole around the shaft. Brass and Aluminum get a bit too friendly after a while, this thing called electrolicic reaction, don't ya know.
JD
Originally Posted by binspaul View Post
Hi JD,
Best regards,
Bins.
Old 2nd November 2009, 10:40 AM   #263
binspaul's Avatar
@Frank: What is the purpose of that extra wheel found on the counter weight of the reference arm ? How does that function ?
@JD: Your suggestion on the anti skating wheel really helped in clearing the doubts that I had in my mind. Can we use wood instead of aluminium for the top and bottom plates (Just a thought) ? Please comment...
Best regards,
Bins.
Old 2nd November 2009, 11:00 AM   #264
nicoch58's Avatar
Wow look so nice
scure sound too.....
Old 2nd November 2009, 10:30 PM   #265
Hi Bins,
The knurled wheel/screw can be added to all my arms, ot just the Reference model. It allows(you screw it in or out...) for ever so slightly changing VTF without the risk of altering azimuth when attempting to slide the main counterweight forward or backwards by a tiny amount.
One full turn alters VTF by ~ 0,03gr.
Best,
Frank
Old 3rd November 2009, 03:54 AM   #266
binspaul's Avatar
Hello Frank,
1. Can we use wood/acrylic for making the top and bottom parts as they are easier to work with than aluminium ?
2. Where is the GROUND WIRE attached to the arm ? Is it to the main screw that is used to fix the arm to the base ?
Best regards,
Bins.
Old 3rd November 2009, 08:34 AM   #267
krishu is offline krishu  Europe
krishu's Avatar
as there is no electrical connection between arm tube and tonearm base (unless you use carbon thread ) you must connect ground wire to the arm tube
Christian.
Visit my DIY page at www.krishu.de
Old 3rd November 2009, 09:54 AM   #268
binspaul's Avatar
Hello Christian,
Nice to see you back on this thread. Ok, I agreed to your suggestion of connecting the GROUND WIRE to the arm tube. But, where ? Which point will be the best ?
Best regards,
Bins.
Old 3rd November 2009, 10:20 AM   #269
zeonrider's Avatar
Hello Frank,
Best regards,
Bins.
Maybe on thin metal plate above head.
Regards zeoN_Rider
Old 3rd November 2009, 10:28 AM   #270
krishu's Avatar
IMHO the ground wire should be connected to the arm tube as close as possible to the tonarm bearing, i. e. not at the headshell. But that might work as well.
Christian.
My DIY Turntables and Schroeder based tonearm konstantin Analogue Source 24 26th March 2010 06:35 AM
Linear tracking tonearm vs. Pivoting tonearm Don Nebel Analogue Source 1 4th November 2007 11:49 PM
DIY Schroeder "Clone" Capt Zach Analogue Source 18 3rd March 2006 07:57 PM
Page generated in 0.10400 seconds (66.39% PHP - 33.61% MySQL) with 11 queries
