Old 8th April 2003, 07:26 PM   #11
mgreene is offline mgreene  United States
Default Repelling?
Ummm...
The magnets are attracting eachother in the Schroeder - or I'm far dumber than I thought I was
My understanding is that the pivot is the "string" that the arm is hanging on and the mobile magnet (in the arm) attracting the stationary magnet (on the base) keeps the pivot stable.
Mike
Old 8th April 2003, 11:03 PM   #12
diyAudio Senior Member
fdegrove's Avatar
Default SCHROEDER.
Hi Mike,
As I said, I didn't really look into the design.
Only problem I see is the drainage of vibrations emanating from the cartridge which is probably why the designer uses all kinds of woods.
The attracting magnets are an interesting idea though, I guess I'll have to to my homework on this.
Frank
Old 10th April 2003, 04:37 PM   #13
Default Re: SCHROEDER.
I thought about this (a Schroeder clone) prior to settling on my air bearing arm. Wouldn't the vibrations simply drain via the magnetic field (i.e. heat)?
One thought that occurred to me was using rare earth magnets to stabilize a unipivot. But, that's another thing all together.
Anyway, similarly to the Ladegaard air-bearing design, this approach has the benefit of quite low cost. You don't have to commit a lot of funds to experiment.
Someday, I may give it a try.
Paul Ebert
Old 10th April 2003, 04:45 PM   #14
Default Schroeder vibration
Why can't the built up vibrations escape via the pivot string to the arm pillar?
I agree that it looks cheap to try. I've started to line up some parts.
Mike
Old 10th April 2003, 04:52 PM   #15
fdegrove's Avatar
Default RE:RE:Schroeder
That's about the only path there is that would provide a little drainage.
Paul,
The magnetic field won't couple vibrational energy throgh the air.
With an airbearing the pressure field of the air provides a coupling path.
I used to know all the theory behind all that stuff but it's getting rustier by the day.
Good on you Mike.
Keep us posted please.
Frank
Old 10th April 2003, 09:01 PM   #16
Default Re: RE:RE:Schroeder
Hmm, (dusting off my antiquated physics...)
The magnetic field creates forces that act to damp the components of any vibrations that are perpendicular to the field. It does this by inducing currents, in the magnetic material - not the air, which are then converted to heat in that material (unless they are drained in an electric circuit of some sort).
So, there is an energy coupling, but it's independent of the air.
Am I missing something?
Paul Ebert
Old 10th April 2003, 09:10 PM   #17
Default RE:Schroeder
Thinking about this further, I'm not saying that the magnetic field drains all, or even a majority, of the vibration. I do think that the 'string' would drain quite a bit. Perhaps the way to think about this is that the magnetic field preloads the string 'bearing', by increasing the tension on it and thereby making it a more effective energy drain. But, I do think that some energy would be converted to heat.
The main point is, however, that this may not be any less effective at draining energy away from the cartridge than a typical physical bearing. It all depends on the strength of the magnetic field and the elasticity of the string. At least that's how I see it (which could very well be wrong...).
Paul Ebert
Old 10th April 2003, 10:39 PM   #18
fdegrove's Avatar
Default RE:RE:RE:SCHROEDER.
Interesting.
Are you sure about this?
If so, any idea on how to find more technical info on the net?
Frank
Old 11th April 2003, 01:33 AM   #19
fdegrove's Avatar
Default PHYSICS.
In case we're both in need of a refreshment course:
ERIC WEISSTEIN
Frank
Old 11th April 2003, 03:26 PM   #20
Default Re: PHYSICS.
Interesting.
Yes, this is interesting stuff. I feel fairly confident about it, but it has been over 20 years since I studied it in college.
ERIC WEISSTEIN
What an amazing resource. Thanks!
Paul
My DIY Turntables and Schroeder based tonearm konstantin Analogue Source 24 26th March 2010 06:35 AM
Linear tracking tonearm vs. Pivoting tonearm Don Nebel Analogue Source 1 4th November 2007 11:49 PM
DIY Schroeder "Clone" Capt Zach Analogue Source 18 3rd March 2006 07:57 PM
Page generated in 0.09313 seconds (77.86% PHP - 22.14% MySQL) with 11 queries
