| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#161 |
I started out to install magnetic suspension and inverted Y strings on an old DIY WTA. results were encouraging except for the electric guitar effect with the stylus resting on a record, not spinning, and tapping the strings held taught by the magnets. In #160 above, I requested help in getting around this problem. No replies yet, but I did do some more investigating and testing. In another post it was mentioned that decoupling the counterweight from the arm tube was very important. My arm tube and CW assembly were taken straight from the WTA. For starters I hung the CW from the arm tube with a few inches of soft cloth ribbon. The electric guitar went home! So next I bored out the CW making a 1/2" dia hole. Inserted a Sorbothane plug drilled out for the 1/4" dia arm tube. Now tapping on the strings or directly on the arm tube gives but a dull thud. Rapping on the plinth gives but dull thuds and no groove jumping until I really whack it. Whacking the playing disk on the edge of the disk gives little to no sound in the playback except for right next to the cartridge, and that is slight. So there has been a major improvement. The played back sound is cleaned up significantly as well. I think I can see where decoupling the CW from the arm tube would clean up arm tube resonances. I would not expect such a great reduction of energy from the vibrating suspension strings. Perhaps the strings are still vibrating, and such vibrations are still being coupled onto the arm tube, but the sorbothane isolator is sucking them up and they are not being converted to electrical energy by the cartridge. Any thoughts on this?
Bill BTW: I have replaced the original Perspex disk with an aluminium disk to aid in eddy current generation. Perspex does nothing for eddy currents. As yet I have some reservations about the eddy current concept in the Schroeder arm bearing. We will leave this issue for a later discussion. |
#162 | |
From post #44(fdegrove)
I simply lack the facilities to make this tonearm, but would still like to see the drawing. Where do I get it and could it be translated (because I can barely speak my own language, let alone German...) stew
stew ☮ -"A sane man in an insane world appears insane." |
#163 |
I have a few questions on the arm wand design: 1. What arm length should be better - a 9/10/12 inch ? 2. What should be the best tube diameter value - 1/4" inch or more ? 3. Should the arm wand be tapered towards the front end or can it maintain the same diameter ? Regards, Bins. |
#164 |
12" arms have substantially better tracking accuracy compared to 9" or 10". It sort of depends what table you plan on using it with and if a 12" can be mounted on the plinth or if an external arm "pod" is to be used.
I would look at something like a Clearaudio Unify12 as a guide for O/S and O/H or perhaps use something with an adjustable O/S headshell type (as used by Clearaudio, Schroeder, etc.) stew
#165 |
Hi Stew,
Did you get the premotec motor ? I am planning to use it on my custom build table. So, mounting won't be a major issue. As your suggestion, I will go for 12''. ![]() The arm will be based on the Schroeder tonearm. The tube will be made of wood (ebony/teak). What should be the required tube diameter ? Is that a critical factor in the arm performance ? What about the arm shape - Round or tapered ? Regards, Bins. |
#166 |
Last day, I had a talk with a musical instrument maker. What he suggested is to use teak instead of ebony; as teak is more resistant to climate changes and is much lighter. He also suggested me to try out mahogany. Any idea on this wood ? When I did a Google search, I came to know that it is used in musical instruments making. See the link: http://en.wikipedia.org/wiki/Mahogany Any suggestions ? Best regards, Bins. |
#167 | |
Mahogany is light and stable. It is used in guitar necks, and and blocks (parts internal to the instrument) and is rot resistant. So now you CAN bring your turntable on you yacht! |
#168 |
1. What about the acoustic properties of the wood (Which one will be better: Mahogany or teak or ebony) ?2. What will be the best tonearm diameter for this (Will 1/4" be enough) ? 3. What should be the best tonearm hole diameter (Thin walled tonearm or thick walled tonearm) ? Best regards, Bins. |
#169 |
binspaul,
I'd consider 3/8" or so as a minimum. As most wood is somewhat self dampening, I wouldn't worry about a taper, unless you have access to either tapered pieces or a lathe or woodworker friend Mahogany has a straighter grain and is easily worked with. Teak has less straight grain. Ebony is very dense. Unsure of working properties, but all else being equal, will resonate at a higher frequency than either teak or mahogany. Personally, given the options listed, I'd look for a "tonewood", so mahogany would be my choice. PS: can only get the Premotec directly out of Holland, so unlikely I will go that route.
#170 |
I have access to the wood workshop. So, tapering will not be an issue. Which model will be better: 1. Drilling a fine hole through the wooden tube -> This will result in a small hole and hence the arm wand will be much heavier. 2. Splitting the tube into 2 or more small pieces and creating a cavity (Joining the pieces will give us a round hole) Also, how can we address the tube resonance ? Do we need to damp the tube using some damping elements like foam or sad or something else ? Best regards, Bins. |
| My DIY Turntables and Schroeder based tonearm | konstantin | Analogue Source | 24 | 26th March 2010 05:35 AM |
| Linear tracking tonearm vs. Pivoting tonearm | Don Nebel | Analogue Source | 1 | 4th November 2007 10:49 PM |
| DIY Schroeder "Clone" | Capt Zach | Analogue Source | 18 | 3rd March 2006 06:57 PM |
| Page generated in 0.13650 seconds (80.81% PHP - 19.19% MySQL) with 11 queries |
