Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 1st February 2004, 09:44 PM   #101
Jax is offline Jax
I have always wonderd, why bend the arm? Is there any reasonable explanation as to why some arms are bent?
Of the TT's I have owned, only one had an S-shaped arm, the AR. I also had an ERA with a straight arm. I could not hear any difference in tracking between these two. But that was long ago, around 1985 when I went digital and stayed digital until last Friday. I could no longer look at my old collection of vinyl unplayed for almost 20 years.
So I bought a Pro-ject 1 Xpression. It came with a straight carbon-fibre arm and an Audio Technica AT-95 installed. I thought I would find a good cartridge later.
I'm deeply impressed with this TT, even with the AT-95. It can play my most warped record. None of my others could. It has to be the lightweight carbon-fibre arm. My reasoning would be that an S-shaped arm would have a higher moment of inertia while a straight has the lowest possible.
Geometrically, none of the arm shapes track better than the other but the straight will have a lower inertia.
Maybe I should do something with the old AR like a new arm? I no longer have the ERA unfortunately.
Jan
Old 2nd February 2004, 01:23 PM   #102
krishu is offline krishu
krishu's Avatar
Hello,
we made draweings before machining, of course. I some time i will publish the most important ones on my site www.krishu.de
so far, there are only pictures.
But I think it really is not necessary to have drawings. What is so difficult to think about? There is not just one proper solution. Everyone of you might have seen a tonearm so he/She can imagine, which diameter, length of pipe etc. can be used. Size and shape of magnets has been discussed here before. Weight and Size of counterweights can be figured out ... and apart from all that: we ourselves just thought and tried, but did NOT simply copy. So there may be mistakes or less good details in our solution. Would you like to copy them as well?
Cheers
Christian.
Visit my DIY page at www.krishu.de
Old 2nd February 2004, 03:40 PM   #103
Magura is offline Magura
Magura's Avatar
Default copy....sounds like a bad word
Nope, i have no intentions to copy your tonearm, but sure intend to copy the good parts of any tonearm. Thats the way to get forward. If we all went back to the invention of the wheel every time we did something, we sure would end up with something close to stagnation.
The point of what i wrote was to make this a group effort. Since the goal is more or less the same for all of us.
Cheers
Magura
Everything is possible....to do the impossible just takes a little while longer.
Old 2nd February 2004, 05:31 PM   #104
krishu's Avatar
Hello Magura*,
I think I see the point.
But we have rarely something to show which can not clearly be seen anywhere. What is interesting is the source of magnets, strings etc. This has been discussed exactly here.
Apart from that I don't refuse to show my drawings. As I hope I said before, I will publish them on my website within next weeks/months. First, I have to edit them.
The most knowledge considering special schroeder tonearm topics I got from the Patent, which obviously and unfortunaltely is only available in German. There is enough description about materials etc.
Apart from that Schroeder specific things you can look anywhere for senceful tonearm pipe, hedshell, counterweight etc. shapes and materials a.s.o.
We used a carbon pipe of 1/2" diameter, stuffed with balsa wood. The rest is mainly bronce, the magnets are 15×5mm N50 neodymium, the "polplatten" are steel and the same dimensions.
Cheers
Christian.
*does that mean the breaks company Gustav Magenwirth Bad Urach?
Old 2nd February 2004, 05:45 PM   #105
Magura's Avatar
Originally posted by krishu
Hello Magura*,
Yes it does...as in the brake people
Do you have a link to the patent?
Im doing ok in german, so i guess it would be fine goodnight reading.
Why did you use such a big carbon tube? Wouldnt 8 or 10 mm be plenty?
Cheers
Magura
Old 2nd February 2004, 06:02 PM   #106
krishu's Avatar
Hello magura,
you can find the link in this thread as well as on my website.
Patent
I did use 12mm pipe because i used it for my unipivot before and because some others use it (e.g. Clearaudio, we call it Klirraudio here ). It is not really heavier that 10 mm pipe but much stiffer. But one has to dampen it, we will do that using balsa wood.
Frank schroeder suggests different wood types as e.g. ebony, which is available from Thomas Scheu www.scheu-analogue.com for example.
Cheers
Christian.
Old 2nd February 2004, 08:40 PM   #107
AuroraB is offline AuroraB
AuroraB's Avatar
Wouldn't self expanding PU foam be enough damping ???
Inserting a welding rod before it cures would give enough space to pull the wires through.....
Old 3rd February 2004, 12:53 AM   #108
diyAudio Senior Member
fdegrove's Avatar
But would also cure the wires whithin...
Frank
Old 3rd February 2004, 08:14 AM   #109
AuroraB's Avatar
There is no problem in removing the rod after curing...
coat it with vaseline or similar, and give it a few twists after curing.....
A thin plastic tube, straw or similar, with a rod inside for strength during placing, is another possibility.....
Actually, -I am very interested in this thread,--
sometime ago I finished the bearing for a Teres,- with good result, and is now planning for a plinth. I have several pieces of heavy 50 mm MDF, but I wanted to something better. Just struck a deal with a guy running a water jet cutting plant for corian, and also PVC, which will probably end as a laminate of PVC and alu for the platter.
Old 3rd February 2004, 12:04 PM   #110
krishu's Avatar
Yes, there are many ways to dampen the carbon pipe. We chose the balsa wood one because of its simplicity.
Cheers
Christian.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
velvetsunrise
Thread Tools
Linear tracking tonearm vs. Pivoting tonearm Don Nebel Analogue Source 1 4th November 2007 11:49 PM
DIY Schroeder "Clone" Capt Zach Analogue Source 18 3rd March 2006 07:57 PM
My DIY Turntables and Schroeder based tonearm konstantin Analogue Source 23 23rd May 2003 08:48 PM
Page generated in 0.18622208 seconds (69.58% PHP - 30.42% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
