Phonoclone 3 - Page 51 - diyAudio
Old 29th May 2009, 12:13 PM   #501
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
Resistors can be sent for the price of postage stamp, but I wouldn't agonize over of getting a certain brand waiting on backorders etc. I second JBdV's idea: Grab a couple locally of whatever you can get. Really, it just doesn't make a significant difference. Also the value for R6 is only rough, it only affects the lowest bass frequencies. 750k would be ok, or 750k + x where x is a second resistor in series, 15k or 22k for example would be more that sufficient.
Old 1st June 2009, 07:12 AM   #502
kffern is offline kffern  Australia
Send a message via Skype™ to kffern
RJM,
I have been sent metal film R7 (75k) instead of carbon.
I can't get 75k carbon from the local electronics shops.
Would the metal film do? I see JBdv got carbon film R7.
Thanks,
kffern
Old 1st June 2009, 08:31 AM   #503
Richard Murdey
rjm's Avatar
That position is particularly unimportant. Metal film will be just fine.
Old 3rd June 2009, 02:13 AM   #504
Richard Murdey
rjm's Avatar
A non-update to post my records for the Phonoclone 3 group buy from Rhys. No orders were received since kffern got his last week.
I did finally get an email from Rhys and we arranged that he would send me my boards. I have not got confirmation that they were shipped however. Rhys is away at the moment on family business.
-- Boards Only --
Received:
||earsandeyes||2||The Netherlands||
Not received:
||rjm||2||Japan|| (no ship date)
||prooptiki||2||Greece|| (no ship date)
||Yan6||2||Canada||(no ship date)
-- Kits --
Received:
||JBdV||2||The Netherlands|| (received May 8)
||kffern||2||Australia|| (received May 27)
Not received:
||FinnC||2||Denmark||(shipped May 2)
||lancer||4||Singapore|| (shipped May 8)
||pchw||2||?|| (shipped May 26th)
||Tham||2||Malaysia|| (shipping "last week in May")
||noelectrix||2||Germany|| (arranged for delivery after June 1st)
||northernsky||2||Italy|| (no ship date)
||enzedone||2||New Zealand|| (no ship date)
Old 3rd June 2009, 08:18 PM   #505
Bords not received too
Old 4th June 2009, 12:07 AM   #506
Richard Murdey
rjm's Avatar
^^^ The pc32e sets from me.
I am well aware of the irony , you don't have to rub it in!
I've never had a delivery from Olimex take longer than two weeks to get here. And I've done quite a few now.
Phonoclone 3 boards were sent from Olimex May 18th. Still nothing my end. I'm starting the search & rescue mission today.
VSPS 300 boards were sent from Olimex May 25th. I haven't got these either, but lets deal with things one at a time.
Will update with any new developments.
/R
Old 4th June 2009, 07:15 AM   #507
rhysh is offline rhysh  United Kingdom
rhysh's Avatar
Send a message via MSN to rhysh
Just a quick post to say I'm still around, but away from home, hence the unreplied emails.
Old 4th June 2009, 10:29 PM   #508
JBdV is offline JBdV  Netherlands
Finally I fired up my Phonoclone 3 boards.
Everything went well!!!
I checked V+ and V- and voltage across the electrolytic caps for correct polarity, just to be on the safe side.
I did this using a lab power supply (2 times 17 V DC)
After that I got 4 diodes and hooked them up to the 2 x 12 V 80VA toroid and connected this power supply.
After that I checked for noise and hum on my system (with no cartridge connected): very low noise, no hum (at an audio level that would be above the pain barrier;-))
Then came the real thing: Starting up my turntable with DL304.
It works very good. To early to comment on the sound quality.
Tomorrow I will replace whatever I put in for 768K with the correct value.
I ordered 50 pieces from Farnell for 2 cents each (not Dale quality, but metal film 1 % it is)
I think have too little bass response but that is probably because of the wrong value for R6 right now.
(No idea what I put in there and I will open the enclosure tomorrow when I have the replacement resistors)
I will get back later with more information.
Old 5th June 2009, 12:28 AM   #509
Richard Murdey
rjm's Avatar
Hi Jan,
Bass response scales in direct proportion to R6, but it's a good idea to give the whole circuit a few days powered up to break in before drawing any conclusions. Also check that C3 is a reasonable size for the input impedance of the amplifier / preamplifier the Phonoclone is connected to.
Richard
Old 5th June 2009, 08:05 PM   #510
Today I replaced what I used for R6 so far for a decent 768K 1 % Metal Film resistor.
I must have been colour blind when I took these resistors out of my stock for R6: I used 39K plus 33K in series in order to create 720 K!!!!! Sheeesshh
And I am able to see the difference between orange and yellow....
So this time testing was much more succesfull: the balance between highs and lows is great! Its all there.
I am convinced that the build was succesfull!!!
Over the weekend I will hook up my best stuff to the DL304/Phonoclone 3 and start real listening.
And of course I need to assemble the toroid into the second housing.
WTB phonoclone boards c.d.s. Swap Meet 1 8th June 2008 09:04 PM
My take on the phonoclone Onvinyl Analogue Source 34 27th March 2007 02:11 PM
WTB: Phonoclone boards KT Swap Meet 0 20th February 2007 06:48 AM
Phonoclone Update rjm Analogue Source 70 6th July 2005 01:42 AM
Copyright 1999-2017 diyAudio
