Old 11th May 2009, 10:27 AM   #461
JBdV is offline JBdV  Netherlands
For all builders on boards that Rhys sent in the last group:
check and double check for the polarity of C10, C11, C12 and C13, beacuse the silkscreen on my boards shows the WRONG POLARITY for those caps.
(Personnaly I don't like those silk screens: just a name and revision number in the ground copper layer are just fine for me)
Old 11th May 2009, 11:37 AM   #462
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
So much time has passed I'd forgotten about this: Rhys' boards are the old 31n revision that had four capacitors reversed on the silk screen. Board 32a and later are correct, including the current revision 32e boards.
I made an image somewhere that showed which caps had to be reversed, I posted it some while back, I'll see if I can find it.
/R
Old 11th May 2009, 12:36 PM   #463
Also Q1 and Q2 need to be reversed (orientation)
Old 11th May 2009, 12:51 PM   #464
Richard Murdey
rjm's Avatar
Yeah, though that wasn't a mistake: those early boards showed TIP40/41 packages for the two pass transistors, the pinouts of which are opposite of the BD135,136 series we eventually settled on on the BOM.
The image attached to this post should explain things, if not read through the two pages of posts prior to that one to get the background.
Old 11th May 2009, 06:27 PM   #465
RJM, I am not complaining, I am very greatful for your nice design, I just wanted to prevent builders run into this issue
Old 12th May 2009, 12:26 AM   #466
Richard Murdey
rjm's Avatar
No no, I didn't read as such. I was just at pains to point out that I only made one serious error, not two... lest anyone think I was completely incompetent.
I have sent a an errata sheet to Rhys and hopefully he will make sure it gets into the hands of those people who have purchased rev 31n boards from him. A copy is attached below.
The 32e boards I've been sending people (all non-beta phonoclone 3 boards ordered through me) do not have these errors.
By the way: here are the new URLs to RJM Audio, for your reference.
RJM Audio Website Limited Sitemap
Main Page
phonoclone.com
DIY Projects list
phonoclone.com/diy.html
Phonoclone phono stage
phonoclone.com/diy_pho4.html
VSPS phono stage
phonoclone.com/diy_pho5.html
Printed Circuit Boards for VSPS and Phonoclone
phonoclone.com/diy_pcb.html
Contruction Guide for VSPS and Phonoclone
phonoclone.com/diy_guide.html
Xreg
phonoclone.com/diy_xreg.html
6DJ8 phono stage
phonoclone.com/diy_pho3.html
The Gainclone
phonoclone.com/diy_gc.html
Twilight hybrid headphone amplifier
phonoclone.com/diy_twi.html
Szekeres VE headphone amplifier
phonoclone.com/diy_sze.html
Szekeres-JFET input headphone amplifier
phonoclone.com/diy_head.html
Old 14th May 2009, 10:31 AM   #467
Sorry ignore please
Old 25th May 2009, 01:00 AM   #468
Richard Murdey
rjm's Avatar
Some works about the phonoclone kits from Rhys.
I'm getting far to many emails from people who haven't received kits that Rhys said he'd posted.
He does not reply to my emails, and others I've contacted have also not been able to contact him.
If you have bought kits I suggest opening a Paypal dispute right away. If you get the kit, fine, you can close it, if not, then you should be able to your money back.
I also recommend that people do not purchase kits from him in the future.
Richard
Old 25th May 2009, 02:18 PM   #469
can I use x reg at 5V to supply digital section of DAC
Old 25th May 2009, 02:30 PM   #470
Richard Murdey
rjm's Avatar
It's a relief to deal with something other phantom kits for a change!
Yes, the xreg can be set as low as you need. For 5V the transformer secondaries can be lower. The worksheet should help you make the necessary alterations. Email me if you don't have it.
/rjm
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
WTB phonoclone boards c.d.s. Swap Meet 1 8th June 2008 09:04 PM
My take on the phonoclone Onvinyl Analogue Source 34 27th March 2007 02:11 PM
WTB: Phonoclone boards KT Swap Meet 0 20th February 2007 06:48 AM
Phonoclone Update rjm Analogue Source 70 6th July 2005 01:42 AM
Page generated in 0.10512 seconds (77.35% PHP - 22.65% MySQL) with 11 queries
