Old 7th January 2010, 10:35 AM   #101
Onvinyl's Avatar
Hi syn,
thanks a lot for your reply. I hope you don't mind discussing some more practical issues here.
In your schematic you specify the fets running at around 4.5mA. The Fets I have happen to be around 7-8mA IDSS, so might settle around 6mA with 2.2 Rs.
What is the usable range, before Q203/205 will starve out for current? What is the supply voltage out of the reg, +/-15V? What is the optimal/targeted current feed for Q203/205?
I cannot see any reasons not to use LM49710 for U203/U204, which I already have, or are there any? Maybe it's just me, but I found them to sound better in a riaa app and less prone to instability as well.
Thanks again,
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 7th January 2010, 12:22 PM   #102
syn08 is offline syn08  Canada
Originally Posted by Onvinyl View Post
Hi syn,
Thanks again,
Rüdiger
All excellent questions.
1. JFETs should be around max 8mA Idss. If more, indeed there's a risk of starving Q203/Q205. If JFETs have more than 8mA Idss, you may want to adjust R203/R237 and increase a little the current through R202/R240
2. There is no strict bias for Q203/Q205. 3-5mA or more is ok, but don't over do it, otherwise you'll have to manage the heat.
3. The supply voltages are +/-22V
4. You need opamps that support +/-22V. LME49710 usually are fine (I tried them myself), but you are outside the data sheet specs, so no guarantees. Nat Semi is manufacturing an excellent +/-22V audio opamp (LME49870) but unfortunately it comes in SMD only, so you need adapters. My suggestion would be to install DIP sockets, you may decide later what opamps you like. BTW, from the datasheets, it looks like LME49870 is nothing but LME49710 tested and guaranteed at +/-22V.
Old 30th January 2010, 06:01 PM   #103
Onvinyl's Avatar
Hi.
I'm fighting with the placement of the input fet's. The photo on your website gives the imagination, that whether the p-fets are placed near the positive rail or the fets are reversed (beeing d-g-s at front view, as opposed to s-g-d for the 2sk246). I know that the 2sk170's work when reversed, but I'd like to know what is going on there. For sure, I need a break...
Rüdiger
Old 31st January 2010, 03:02 PM   #104
Hi.
Rüdiger
Old 31st January 2010, 03:13 PM   #105
Onvinyl's Avatar
Syn08,
thanks a lot. According to the datasheet, they are reversed. The 2sj103 in the regulator are placed the right way round, and compared to the 170's, the pins are swapped.
The 170's do definitly work 'backwards', but I don't know if that is really aquivalent spec- and soundwise.
Rüdiger
Old 31st January 2010, 03:39 PM   #106
It doesn't matter, but if you have any doubts, just install the 2SK170/2SJ74 rotated by 180 (swap D and S).
Old 1st February 2010, 04:32 PM   #107
Default Matching input stage JFETS
syn08,
Would I be correct in assuming that you matched Idss on the input stage JFETs? If so how accurately did you find it necessary to match them? Did you match any other parameters?
Thanks in advance.
JCM
Old 1st February 2010, 05:05 PM   #108
Originally Posted by analog_guy View Post
syn08,
Thanks in advance.
You don't have to match them at all; just use the BL class out of the tube, the servo is taking care of the offset due to any mismatch. OTOH, matching JFETs has absolutely no impact on the overall noise. High Idss devices won't do any good in terms of performance, but if it happens to get parts with an average Idss over 8mA, then you may need to increase a little the current through R202/R240 by adjusting R203 and R241. Don't do this without any good reason, it will only increase the power dissipation in Q203/Q205 (currently running in free air, no heatsink is required).
Old 17th March 2010, 09:12 PM   #109
Barniboy's Avatar
Default LP797 by Dennis Colin
Originally Posted by syn08 View Post
As you probably know, I recently decided it's time to enjoy my old vinyl collection. I got a VPI HW-19 MK3 (which I eventually upgraded to the Scout platter and bearing), with AudioQuest PT-9 tonearm and Benz Micro Silver cartridge. I got originally a NAD PP3 phono preamp, paying $150 for essentialy a couple of 5532 opamps in a small metal case. After a little listening, I was having difficulties plotting the fastest course to BayBloor Radio to return the thing...
So, not willing to pay $1000+ for what it is supposed to be a decent phono stage, I decided to DIY one. The other good reason was to finally do some decent comparison between a fully IC based solution (around the new OPA827) and a hybrid solution (2SK170 input stage plus gain opamps). Originally I was planning to start with the full IC design, but some discussions on this forum made me decide to start with the hybrid beast.
Dennis Colin's implementation published in AudioExpress "The LP 797 Ultra-Low Distortion Phono Preamp" audioXpress - Articles and Addenda with a few tweaks is the core signal chain. This implementation has a serious problem though: the PSRR is very poor. Colin tried to mitigate this issue with a primitive power supply and a 10,000uF capacitor on the input stage power rail, which is obvious a poor solution. So I've decided to add a Jung super regulator on the same board, together with a TLE2426 rail splitter/virtual ground. I've also decided to put all opamps on sockets, to be able to evaluate the measured and sonic results.
I gave up the idea to switch the input with some fancy Panasonic relays mostly because I was unable to find any good reason why to read a MC cartridge with a 200ohm input impedance. This being said, for switching the gain (MC/MM) in the second stage (where everything is already at 20-30mV) and muting the output I was able to use the same cheap (but not poor) Hamlin reed relays that PGP uses on the input.
Here's a picture of the finished board. The metal case is waiting for drilling (will happen tomorrow) then the evaluation will start. From what I was able to quickly measure on the board, it's stable with AD797, OPA627 and LME49710, RIAA is +/-0.1dB (but I had to sort the RC's to better than 0.5% nominal and to 0.1% between channels). Noise is around 1nV/rtHz with AD797 in the input stage loop (I'll confirm this after the whole thing is cased and properly grounded).
Will be back in the following days (and of course on my web site, which God knows when I'll find the time to update) with schematics (nothing really spectacular) the implementation (I think the layout is very good) and the measurement and sonic details. Now I need some sleep.
Hi Syn08
A bit late by now, I admit. But your work on the LP797 is very interesting, corresponding to my ideas entirely. How has things progressed ?
Do you have any PCB's / schematics / partslist ?
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
Looking for a great DIY-Preamp for MICs (48v) TobWen Tubes / Valves 12 29th February 2004 09:50 PM
Phono Preamp. victor Pass Labs 0 24th October 2001 07:11 AM
Page generated in 0.11270 seconds (83.85% PHP - 16.15% MySQL) with 11 queries
