Unipivot principle
Unipivot principle
Old 3rd April 2003, 09:02 AM   #1
peterr is offline peterr  Netherlands
peterr's Avatar
Default Unipivot principle
Triggered by the recent threads on unipivot-arms I have been thinking about the actual pivot point.
In principle it looks like nr.1 in the drawing below: a cup resting on a perfectly sharp pin. But I assume that in practice it looks more like nr.2: both pin and cup wil not be perfect.
This makes me wonder if something like nr.3 using one ball might be a better solution?
Am I right in my assumptions?
Has this been done before?
Does it/should it work?
Please comment.
Keep an open mind. It helps.
Peter
Old 3rd April 2003, 11:22 AM   #2
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
As to your sketch #3,--
one ball resting atop of 3 balls i a lower cup has been suggested in another thread, last year sometime....
Sapphire and ruby balls are rather cheap at Smallparts Inc., I beleive.???
Old 3rd April 2003, 08:39 PM   #3
DrewP is offline DrewP
Default 4 Ball Pyramid
Yup, the 4 ball pyramid (always self centering, no chatter, low wear and still low friction) is used by Wilson Benesch in their unipivots and it was the approach i used fro the pivot of my own DIY.
I got 4 ruby/sapphire ball bearings 1/8 of an inch in diameter, mounted one on a brass thrust plate to bolt to the arm housing and 3 in a cup machined into the top of the arm pillar.
Bearing housing and arm are shaped from rosewood, arm tube is a 1/8 square brass tube set into the side of the arm wand, counterweight and stub are brass as is the thrust plate, arm pillar and base. Headshell is aero grade high tensile aluminium.
As yet I have not wired it up, fitted side weights or antiskate.
I'll try to get some photos for you soon.
Drew
Old 6th April 2003, 08:02 AM   #4
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Cheap source of precision bearings.
Ball point pen tips are high precision, small bearings. Consider, the fit of the ball in the socket is so precise that a metered quantity of ink flows through the gap.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 12th June 2006, 12:26 PM   #5
seppstefano is offline seppstefano  Italy
seppstefano's Avatar
Default Re: 4 Ball Pyramid
Drew
...any photo, yet?
Stefano
Old 12th June 2006, 02:18 PM   #6
too299 is offline too299  Singapore
Default Re: Unipivot principle
Please comment.
It does not matter which of the application you apply as long as the contact point is precisely matched. Which mean it must cross the Hi-Fi News track(side 1 band 8) without distortion
Old 11th July 2006, 04:19 AM   #7
mosin is offline mosin  United States
mosin's Avatar
Although Wilson and others use the pyramid bearing, it was first used in the Magnepan Unitrac tonearm. The information on it that can be downloaded from the Vinyl Engine is a very good read.
Unipivot principleHide this!Advertise here!
Slit cone principle?? Elbert Multi-Way 11 18th December 2009 09:57 AM
An interesting principle phase_accurate Multi-Way 9 30th June 2008 02:34 AM
The Translinear Principle rtarbell Everything Else 0 6th April 2006 06:03 AM
Which principle should I prefer? ChocoHolic Subwoofers 6 20th June 2004 10:56 PM
