FM IF Filters
FM IF Filters
Old 27th October 2008, 09:07 AM   #1
Juergen Knoop is offline Juergen Knoop  Germany
Juergen Knoop's Avatar
Default FM IF Filters
I have got some 4 pin IF filters from Murata.
Can't find any data on them. I would appreciate any info.
Do the inputs float or are they ground referenced?
What about pinning and filter curve?
Old 27th October 2008, 05:41 PM   #2
kevinkr's Avatar
FM IF Filters
Check out the tuner information center here: http://www.fmtunerinfo.com/
Join their forum and someone should there should be able to answer your question.
Indispensable if you are into collecting, fixing, modifying or building your own tuners..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 27th October 2008, 07:02 PM   #3
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
These are old ceramic filters for 10,7 MHz. I used similar filters some 20 years ago, but cannot remember the bandwidth coding.
They are most probably ground referenced, with the two innermost pins connected to ground, but not necessearly internaly connected - try ohming them.
They rely on proper drivind and terminating resistance, and are possibly built for 330 ohms both ways. In/out can be switched , - i.e pin 1 and 4 can be used for input or output at will.
I may have an old Murata catalogue somewhere, but won't have time until X-mas to look for it, as I'm moving house these days and must leave for a 4 week project work on the 15th...sorry.
There are some info here:
http://www.murata.com/av/index.html
Try E-mailing them for further info, or the above referred fmtuner pages may be able to help you.
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 29th October 2008, 08:33 PM   #4
thank you , don't know there was a dedicated tuner board!
regards
Old 30th October 2008, 03:35 AM   #5
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Last time I used something like this they were inner pins ground outer pins specified ~300 Ohms drive impedance. There are narrow band coms versions of these so they might not work for broadcast FM. My DIY tuner was great. I had a friend order the front end as a replacement part from Heathkit, wired up an IF with two of these and used the RCA (????) demod with the MOTO stereo chip. Sort of equaled anything around at a reasonable price.
I forgot, I ordered an early sample of the first Fairchild TTL 100MHz divider (1W!) and some fancy LED displays and hardwired a -10.7 digital circuit. It worked great except for the digital crosstalk blocking several channels.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
FM IF FiltersHide this!Advertise here!
RC filters Sch3mat1c Parts 1 29th April 2011 09:34 PM
Ac filters jleaman Everything Else 17 31st May 2006 08:45 AM
PSU filters kyrochan Power Supplies 1 2nd April 2005 05:05 PM
PI filters Prune Tubes / Valves 3 26th September 2004 10:16 PM
Filters Mr. Bungle Solid State 2 31st July 2004 06:08 PM
