Old 14th October 2008, 05:41 PM   #1
Default Sansui TU-919 output uPC1190C
Just picked up a Sansui TU-919 and immediately found power
supply problems. Looks like cap and/or rectifier problems.
(AC on DC rails). I'm just going to re-cap whole thing and probably
do rectifiers as well. I noticed audio stage has NEC uPC1190C
and cannot find any datasheets on it whatsoever. One of the
datasheet sites has some specs, but does not cover pinout, etc.
I'm thinking of upgrading that to something more modern as
well and would like to find either original datasheets or what
modern devices are pin compatible. If not pin compatible be
able to at least build adapter board for use with OPA2604,
OPA2132 ,or OPA2134 of which I have tons of any of those
on hand.
Old 31st October 2008, 04:46 PM   #2
Anywon? Anywon?
Old 31st October 2008, 05:27 PM   #3
kevinkr's Avatar
Tuner Information Center is your friend and the forum is worth joining. You'll be able to get lots of good advice on tweaking/repairing the TU-919.. (Very nice tuner when working)
http://www.fmtunerinfo.com/
Indispensable forum and site for tuner tweakers, fmdx'ers, audiophiles, etc.
www.kta-hifi.net
Sansui xr q9 nik75 Digital Source 0 14th June 2009 11:12 PM
sansui au111 output transformer TJ Tubes / Valves 2 27th May 2006 09:20 PM
Sansui 1000A output transformers JohnG Swap Meet 7 27th February 2006 11:39 PM
FS: pair of ORIGINAL Sansui au-111 output transformers Mark Hathaway Swap Meet 0 8th March 2004 01:02 PM
Sansui 500a Output Transformer KIERANPHILLIPS Tubes / Valves 0 26th March 2002 10:53 PM
Page generated in 0.07745 seconds (71.11% PHP - 28.89% MySQL) with 10 queries
